Alarm Systems Discussion related to installation, diagnostics, and purchasing of alarm systems
Security Device, Please help Identify
Old Nov 20, 2006 | 11:44 AM
keithguts's Avatar
OK all, I need your help. 1st off, can you tell me if this comes with a 95 4runner. http://i40.photobucket.com/albums/e2...s/P8150001.jpg Also is there anyway of checking it out. I just found it under my dash. It is on the drivers side. I don't see any switches of any kind except something in the pannel right above my left foot, but it seems to have no switch in it. It seems to be a small toggle switch, but broken. My question is, haw can I find out if this thing is hooked up or not. Please help. If you need any more info, Please ask. Thanks
Old Nov 20, 2006 | 12:06 PM
paxil4x4's Avatar
Drama Queen/Banned
It's an old alarm system. the toggle switch is for valet/service to disable the unit.
I have removed quite a few alarms, but would not recommend doing yourself unless your really familar with wiring circuits.
Old Nov 20, 2006 | 12:10 PM
keithguts's Avatar
My question is tho, can this unit still be working. How can I tell??
Old Nov 20, 2006 | 12:15 PM
paxil4x4's Avatar
Drama Queen/Banned
Your not going to know unless you have the remotes
Old Nov 20, 2006 | 12:17 PM
keithguts's Avatar
OK so I guess what you are telling me is to leave it be.
Old Nov 20, 2006 | 12:18 PM
1styota4X4's Avatar
you can get a new clicker from toyota that is what I did for mine and it only cost 45 dollars...
to test plug the white clip in to the brain the black box. with the key in the on position flip the toggle switch the led on the left of dash should light up letting you know you are in valet mode. At that point it is kinda a crap shoot to go buy a clicker and program it.
My truck was missing the brain and i went to a junk yard found one and hooked it up and it worked...so that is what i am using
Old Nov 20, 2006 | 12:24 PM
keithguts's Avatar
Did this come with your runner. Is it standard for a 95??
Old Nov 20, 2006 | 10:04 PM
reggie 00's Avatar
I'm thinking its a dealer add on thing.
My brother use to go to all the dealerships in the area and install alarms and what not for his work. Code alarm is one of the ones he use to do.
If it hasn't given you any problems there is probably no reason to mess with it. If you are looking for an alarm to use you can do better.
Old Nov 23, 2006 | 06:57 PM
wurmy77's Avatar
You should be able to contact Code alarm for instructions and replcement remotes or at least find a dealer here
www.code-alarm.com
justdifferentials
14
Jun 11, 2017 08:36 PM
JUICE222
Oct 13, 2015 08:50 AM
Williamemslie
14
Oct 5, 2015 09:28 AM
Rcbc92
Sep 26, 2015 03:00 PM
Bill854x4
Sep 20, 2015 04:32 PM
