transfer case growl
Old Nov 24, 2010 | 05:52 PM
ballzout's Avatar
transfer case growl
transfer case growls whether in 4wd or hubs locked does not do in 2wd with hubs free. more of a low fluid sound case diffs and hubs are not getting hot. thinking its a bearing in there but not sure. how much would it cost to rebuild a transfer case? could it be something wrong with the front end? maybe hubs are need to be repacked with grease? 1980 yota pickup 22r ?transmission and transfer case?
Old Nov 28, 2010 | 01:28 AM
ballzout's Avatar
ok soo its not a growl its a rattling noise. checked it out. on the front drive line off the t case there is 2 u joints and a coupler or something between them and its kinda loose has not been greased in a long time looks like and i think thats my problem if anyone knows about this let me know thanks
Old Nov 28, 2010 | 08:29 AM
elk4's Avatar
lololol im going threw the same thing right now and i took mine apart last night and found out that the niddle barrings in the little ball in the middle were missing some just look for a new drive line if you find 2 let me know thanks
Old Nov 28, 2010 | 09:07 AM
82blueyota's Avatar
that is your double cardan joint and ther is a little ball on a post in there ther is also a little dust sheild that is inside that might be making the noise you can get the inner ball from napa or murls drivline in spokane.there are 2 sizes
napa pn for the rebild kits are
.467 ball stud puj 613
.513 ball stud puj 614 cost 51.00
murls was only like 30 or 40 bucks
Old Nov 28, 2010 | 09:09 AM
82blueyota's Avatar
just toss the dust sheild i've run mine for about a year now without it didn't seem to affect it.
82blueyota's Avatar
here are the parts
Old Nov 30, 2010 | 02:39 PM
elk4's Avatar
so is that the noise you have?? if not what is it? i hope this fixed my problume i also had a shake so i started in the cheepest spot to
Old Nov 30, 2010 | 03:09 PM
82blueyota's Avatar
take your shifter boots off and drive it around you can see and here the front drive shaft better.thats what i did
Old Nov 30, 2010 | 04:35 PM
elk4's Avatar
ok i went to go put that ball in and it took a little bit of hammer taping to get it in, is the race suppose to come out cuzz i could not separate it from the ball the old ball fell out win it took every thing apart in the first place
Old Dec 2, 2010 | 10:40 AM
ballzout's Avatar
thats what is making the noise i tried to grease it did not work took out the grease fitting and no grease inside the zerk. i took it to 5 auto parts and even a 4x4 shop and finally found one that might work going to try it let you guys know if that works
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Phantez
Sep 30, 2015 08:24 AM
Toys4parts
Sep 26, 2015 01:56 PM
