Starter issues in 3VZE
Old Oct 25, 2009 | 05:58 PM
j0rdanisme's Avatar
Hey guys,
I was recently cruising to the airport, got lost, turned my truck off and it would not turn over again. My stereo works, along with the lights ect. When i put a charger on the battery nothing changes.
Im thinking its my starter. The engine does not even crank over, so thats a pretty good sign (correct me if im wrong). How could i resolve this? I've heard of hitting it with a hammer temporarily helping it, does that work?
Thoughts?
Old Oct 25, 2009 | 06:09 PM
4Crawler's Avatar
See below for some ideas:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Old Oct 25, 2009 | 06:39 PM
j0rdanisme's Avatar
Thats more of a walkthrough on how to rebuild it, i need to get my truck home before I can rebuild it
Old Oct 25, 2009 | 07:42 PM
4Crawler's Avatar
Try a hammer or something to tap on the solenoid in case the plunger is stuck. You can also make a jumper wire to bridge power from the starter power post to the solenoid it to turn over, have someone in the vehicle turn the key to the start position then use the jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#QuickFix
Old Oct 28, 2009 | 01:57 PM
j0rdanisme's Avatar
Hey guys, quick update as i am severely confused now.
So, when my truck is cold it will start fine. When its hot it wont start.
The ONLY thing i can SEE that could cause this is the heat wrap around the cabling beside the exhaust manifold is all cracked and worn out. Could that cause it?
Im lost on this one.
Old Oct 28, 2009 | 02:01 PM
4Crawler's Avatar
If possible, try the voltage test I linked to above. Do the test when cold, note the voltages when it starts. Then test the voltage when hot and see if there is any difference from the cold tests. If so, the problem will lie in the circuit where there is a voltage difference.
Old Oct 28, 2009 | 02:11 PM
j0rdanisme's Avatar
Could heat directly effect the power input/output?
I will try it for sure.
Old Oct 28, 2009 | 02:20 PM
4Crawler's Avatar
Most normal materials have a positive resistance vs. temperature curve, that is higher temps = higher resistance. And higher resistance translates to increased voltage drop in a circuit. The solenoid, for example,pulls about 20 amps when it is on. And, per the FSM, more than 0.5 volts of drop in that line is a cause for concern, and with V=I*R, or R=V/I, you have 0.5/20 or 0.025 ohms between the battery and the starter solenoid will cause 0.5 volts of drop. And things like corroded connections or wires that are corroded up under the insulation have an even more extreme resistance vs. temperature curve.
Old Oct 28, 2009 | 02:33 PM
Kiroshu's Avatar
Go buy you a hammer from wallbobs and hit the starter when your truck won't turn over. If it turns after hitting it then the starter seems at fault. Clean battery terminals. Check voltage when hot and cold.
Old Nov 3, 2009 | 10:23 AM
j0rdanisme's Avatar
Figured out the issue.
The housing around the solenoid connection was all cracked and broken, making it shake and rattle when driving. Oddly enough heat effected it. Fixed!
clok
Aug 1, 2015 09:42 PM
91yotapup
Jul 27, 2015 07:19 AM
ZONAYODA
Jul 13, 2015 07:17 PM
smiley52
Jul 11, 2015 05:16 AM
colinmil
Jul 6, 2015 04:03 PM
