Sound deading project 1/2 way done- pics and impressions
Old Aug 14, 2003 | 08:04 PM
  #81
Bob_98SR5's Avatar
gw,
are you talking about subwoofer foam? or the spray kind that expands? do you have a pic of the rear cargo area w/ the poly foam?
my guest who we took to pismo said "man, its so damn quiet back here compared to my dad's 97" few minutes later, the boy just flat out passed out!
bob
Old Aug 19, 2003 | 03:20 AM
  #82
gwhayduke's Avatar
I used "Great Stuff" polyurethane foam. It expands as it comes into contact with moisture in the air. If you use it, use a little at a time, It expands with such force that it's said to have buckled panels.
Now that all my panels are back in, I'm not pleased. But I believe that a lot of my noise is now coming in the tailgate. So that's my next project. But I may order some sound deadening "paint" for it.
Old Aug 19, 2003 | 08:08 AM
  #83
keisur's Avatar
Originally posted by gwhayduke
I'm not pleased.
Why not?
Old Aug 19, 2003 | 09:24 AM
  #84
socaleric2002's Avatar
Originally posted by Bob_98SR5
I just ordered the McMasters Peel-N-Seal (thanks SocalEric, I finally ordered it) for my doors. I'm gonna pick it up tomorrow and try to apply it tomorrow night or on Sunday. As SocalEric said, the doors make a big difference.
Bob
No prob Bob
I still havnt done mine. All that PnS is sitting in my garage, been too hot out here!!!
Old Aug 19, 2003 | 10:16 AM
  #85
Bob_98SR5's Avatar
Eric,
If you need carpet padding, I got a ton of it. I can bring it to my work in El Monte and then we can meet up and do the transfer.
Bob
Old Aug 20, 2003 | 07:22 AM
  #86
stoutshady's Avatar
Hi all, this last weekend I was so inspired by this post that I went ahead and braved the 93 degree heat and began taking out the headliner of my 97 4runner limited. The weekend before I tried this but could not figure out how to take the rear dome light off. Well, I breezed through that portion of the removal process and was on my way thanks to this thread. I ended up breaking every one of those circular fasteners when removing that damn headliner(had to put serious muscle into it). I did not feel the need to remove the entire liner, just up to where the moon roof starts (mainly because I could not loosen the screws on the driver's side brace handle or whatever you call it). I used Dynamat Xtreme (36sq ft bulk pack: ebay $96) to cover the roof and layed it directly over the foam stuff near the back. I was quite pleased with the sound (or lack of sound) after the Dynamat was laid. The main reason for this project was that I was getting rattles from the cargo area, but the rattles did not go away... It turns out that my sub box is rattling, something is loose in there, but it is on it's way out. I have 2 new 12" Adire Brahmas going in after I install a new 200amp H O alt and Optima yellowtop. Well, here are a few photos of the project:
Attached Thumbnails Sound deading project 1/2 way done- pics and impressions-tests.jpg
Old Aug 20, 2003 | 07:28 PM
  #87
Axo's Avatar
Axo
IMHO - You probably won't gain much from adding acoustic mat insulation around the sunroof on top of the headliner. The configuration of the bracing and the sunroof bracing appears to pretty much eliminate a lot of the noise harmonics above your head.
Based on my research on this and knowledge of architectural acoustics the small areas make a small difference. I attached a photo illustrating this concept used on my doors. The little gaps don't appreciably affect the performance.
The primary benefit comes from three areas:
1. door and side panels
2. roof (important in a SUV - even for heating and cooling)
3. floor boards
Just find a way to kill all that bad sound energy and world will be wonderful once again...
I'm out.
Rich
Attached Thumbnails Sound deading project 1/2 way done- pics and impressions-7-pieces-inside.jpg
Old Aug 24, 2003 | 07:09 AM
  #88
keisur's Avatar
Here's a place you can order bulk Peel&Seal from and in different widths, which is better than Lowe's 6" only width, and at about the same prices:
http://www.rwc.org/u/web/rwcorg/cgi-local/catalog.cgi
and also Peel&Seal's homepage with instructions on how to apply it:
http://www.mfmbp.com/peelseal/index.htm
Old Aug 24, 2003 | 10:07 AM
  #89
gwhayduke's Avatar
The reason I'm not pleased is because I don't notice any difference in road noise coming from the back. But I believe that most of it is now coming from the rear tailgate. I'm going to pull the panels and do something to it...soundproofing paint, P&S or something.
Old Aug 24, 2003 | 08:54 PM
  #90
Bob_98SR5's Avatar
DONE!!!!!!!!!!
I decided to roll the last part into the original write up. This didn't take as long as the rest of the vehicle for two reasons:
1) Door panels are easy to remove
2) Peel-N-Seal is the BEST material to work with. Very pliable, easy to cut, etc.
I'd recommend using PNS for this entire project. Granted, the HTM is a very good, thick material for the floor and the roof, but if you don't have the patience of a 4th grade teacher, use PNS for this project.
The doors:
http://www.4runners.org/articles/sound/deaddoor.html
The entire write up:
Bob
Old Aug 25, 2003 | 06:21 AM
  #91
keisur's Avatar
Bob
haha, I gotta laugh bob. I read your door write-up and thought it was cool you discovered that same "technique" that I used to lay the PnS behind the wires on the rear sidewalls. pull about an inch of the backing and slide down behind the wires and then pull the backing off and press it down. cool.
and as alway's heck of a write-up.
Old Apr 5, 2005 | 08:33 PM
  #92
NorCalVP's Avatar
Just thought i'd bring this thread back from the dead. Out of the many people here that have tried the PNS on their interior's of their trucks, how did you install it? Did you cover every square inch that you possibly could? did you leave gaps? did anyone just use PNS and no carpet pad?... I Am trying to put some PNS in my 84 Tercel Wagon, and got most of the floor covered, but i have about 1 inch gaps between the material. Do i need to fill these gaps in to get the best effect? also is adding the carpet pad that big of an improvement? I don't have any currently, but should in a few months, but really don't want to wait.
Steve
Old Apr 5, 2005 | 09:48 PM
  #93
Bob_98SR5's Avatar
steve,
id definitely put carpet padding on the floor board. and no, i didnt put material on every square inch. some places you just couldnt do that.
the doors make a huge difference re PNS, but putting carpet is not an option there. i have enough material to do another layer of PNS on the doors. i may do that one of these days, but other mods are ahead of it.
bob
Old Apr 5, 2005 | 11:15 PM
  #94
NorCalVP's Avatar
Yeah, at freeway speeds, this little car is so loud that you can't really hear the person sitting next to you. When i removed the carpet in the back, there was nothing in terms of sound deadening material. I've covered quite a bit of it now, and went back to lowes to get somemore PNS to do the rest of it. I'm planning on doing the doors too, but I want to get the whole floor first, and remove the stock padding on the roof (and put PNS + padding up there).
Thanks a bunch for your writeup, it helped quite a bit.
OH BTW I ended up getting those damn roof plugs out without breaking them, I have a set of craftsman precision needle nose pliers that are about 3.5 inches long and pretty thin. They slid right under those plugs. I had to try a few different angles to squeeze the clips in, but they came out no problem.
Steve
Old Apr 6, 2005 | 01:19 PM
  #95
Schuey2002's Avatar
>>"the doors make a huge difference re PNS,"<<
If you seal off your doors, like this >>Click Here<<, you'll get even better results. My passenger door looks just like the one in that link, except I covered EVERY hole, leaving no gaps anywhere. Boy, let me tell you, the difference is night and day!
Old Apr 7, 2005 | 07:58 AM
  #96
phoenix808's Avatar
This helps with your audio system, too, as it creates more of a sealed enclosure for the speakers in your doors (not sure if it matters with a stock audio system, though )
Old Apr 8, 2005 | 03:30 PM
  #97
KZN185W's Avatar
Is that PNS everywhere in the pic?
Thanks
Old Apr 8, 2005 | 07:05 PM
  #98
Schuey2002's Avatar
It's eDead V.1.SE, which looks quite similiar to Peel 'n Seal..
the1998sr5
15
Jul 14, 2020 08:35 PM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
yourrealdad
Jul 21, 2015 11:13 AM
Poncho0206
Jul 10, 2015 06:21 PM
Yotoder865
Jul 9, 2015 07:51 PM
