Old Mar 23, 2016, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Exterior Guides
Print Wikipost
Show us your best cheap mods!
Old May 22, 2008 | 10:33 PM
  #101
907Toyota's Avatar
Re-routed the intake tube to where the drivers-side corner light was with some old vacuum cleaner hose --WIP. I did that so I can make a detachable snorkle without cutting the fenders, also going to be home made extended the diff. breathers. and of course taking off the rear bumber, lower valance and mud flaps.
Old May 25, 2008 | 07:48 PM
  #102
CyMoN's Avatar
I bought a old street sign and made it into a valance skid plate this weekend and cutout two spots for some cheap driving lights
total price was 30$
I used my a/c switch for the light switch blue wire is power black gos to the lights and white is the ground so that the a/c light will light up when you turn on the lights.
Old May 25, 2008 | 09:19 PM
  #103
91Toyota's Avatar
Tach...$35
Old May 25, 2008 | 10:36 PM
  #104
phildelfino's Avatar
I am subscribing.
Old Jun 15, 2008 | 08:26 PM
  #105
nmtravel's Avatar
My cheap mods on my 1st gen
I've got an '87 4Runner where I solved a problem that vexed me for a while. The pulls to release the rear seat-backs, or "plungers" as Toyota calls them, were always breaking, especially while trying to get the seats to lay flat. I thought it over a bit and came up with a solution. I bought a set of old style "security" door lock pulls, cut about 1/4 inch off the top, drilled a hole near the tip, and inserted a keychain ring. Now the seats fold flat without the pulls catching on anything, and there are no plastic bits to break. The door locks cost $5 and I had the rings and washers lying around the garage. Now I can easily lay the seat flat and sleep on the trail.
Another cheap mod I did was install a light in the rear so I can see where I'm going if I have to back out of a spot at night. I didn't want to install it on the underside of the bumper and lose clearance, or the top of the bumper and interfere with the tailgate. So logically I put it on the tailgate. I removed the tailgate cover to make sure I wouldn't interfere with the operation of the rear window and drilled a hole to mount the light. I then drilled a small hole to run the wire through. Once mounted, I ran the power for the new light through the wire harness for the rear window motor and into the cargo area, where I tied it into the power for the rear deck lamp. So not only did I not have to run a wire all the way up to the instrument panel, that light is already on a switch so I didn't have to purchase or install a new switch. I just hit the rear deck light switch and I have a nice little beam to guide my way out. And the light is hinged and can be rotated in any direction. I had everything laying around the garage so this mod cost me absolutely nothing.
Attached Thumbnails Show us your best cheap mods!-copydsc_0024.jpg   Show us your best cheap mods!-copy-pict6845.jpg
Old Jun 15, 2008 | 08:42 PM
  #106
94Runner4x4's Avatar
Originally Posted by CyMoN
rain X all your windows before going out mudding and anti fog the inside windows
we have gone out the last 4 days to a friend of a friends land and they have some very wet and muddy trails first 2 nights I could not see out any window but the front and the mud was starting to cloud up it as well.
I had a bottle of rain X that I bought 5 years ago that I had never used thought I would give it a try and it worked great the mud slid right off the front window and the sides had way less stick to them as the nights before.
I also put it on my lights and it helped with no muddy water collecting on them as well.
Awesome idea, I've never thought of that! I'm gonna have to use this one.
Old Jun 16, 2008 | 08:00 PM
  #107
82greenbeast's Avatar
I wish i had pics, but once i put buckets in my 82' i made a MDF console for inbetween the seats, with cupholders, 6" speaker box and a spot for a maglight and whatever else, Also a big ol' diff. breather, and right now im in the process of trying to rig up a 85' runner skidplate on it.
Old Aug 25, 2009 | 12:10 PM
  #108
k808soljah's Avatar
maglite mod - $5 for mounts and $20 for 3-d led maglite
i mounted mine next to the shifter on the passenger side
Old Aug 29, 2009 | 12:42 PM
  #109
sajidd's Avatar
subscribing
Old Sep 17, 2009 | 12:02 AM
  #110
k808soljah's Avatar
bump.. c'mon guys let's see those cheap mods!!
Old Sep 17, 2009 | 02:47 AM
  #111
85TurboRunner's Avatar
I made my own mud flaps a while back. They aren't pretty but they keep the police off my back. I bought a kit online that came with all the brackets for $26.00. I had my own rubber mat that I got from work. You have to do some customization since they are meant for a semi truck and start out 29" wide. They are also removable for offroading.
Old Sep 18, 2009 | 07:04 AM
  #112
Wes94's Avatar
I picked up a set of AISIN hubs at a pick-a-part for $40 (40 Canadian, so like $3 US..) Another 8 bucks for some grease and now all i need are the gaskets. Anyone know if it's okay to just use black RTV (silicon) instead of having to wait for the dealer to get the paper gaskets in?
Old Sep 23, 2009 | 11:30 AM
  #113
Stuwy123's Avatar
I think 90% of my mods have been in $50.
- SR5 seats
- Removed carpet
- Rear sliding window replacement (plexiglass)
- Roll Bar
- 4 "Baja" fog lights
- Complete sound system (2 amps, 4 speakers and a sub)
- Stinger fuse and wiring
- Rear tube bumper
- Front smitty built tube bumper
- Gap guards (post body lift)
- Electronic cruise control
- Remote Starter
- Brand new CAPA certified front fenders (stickers and all)
Just gotta put in your time and a little cash at Pick and Pull.
And of course, lots of sweat and blood.
Old Oct 23, 2009 | 09:40 AM
  #114
crawlerjunkie's Avatar
.50cal center console
with orig. top box
and a cheapo cup holder
and sense the factory switch's didn't work i relocated and wired my own for the rear window. The one on the left is for lights the right is the rear window
the radio wasn't cheap but the mount was, hell if i sell the rear view i could make money!
Old Oct 23, 2009 | 10:50 AM
  #115
mtnfreak's Avatar
4 years and counting! Great work everyone - keep those cheap mods coming!!!!
Old Oct 24, 2009 | 07:54 PM
  #116
mtnfreak's Avatar
The only things I've done lately were mostly maintenance items. For those of you who want your plastic surfaces to be black again, the Krylon Fusion spray has worked well for me. Just be sure to follow the directions for surface prep. Same goes for metal surfaces and Hammertite spray (I think it's under the rust-oleum brand now).
One 'mod' I was glad to have done before summer was a couple of 12v fans. You can pick them up at any electronic supply store. Just wire them up for a cigarette lighter (or whatever power source you have) and place them where needed. Very low power draw so they can run a long time without draining your battery. I used extra long wires so they'll reach well outside the truck.
Old Oct 24, 2009 | 08:31 PM
  #117
toyospearo's Avatar
Here is a gas jerry can mod I did a few weeks ago. I started with 1" steel, 1/8" steel plate, turn knob, rubber and steel cord to lock it. The cage is mounted to the tool box with 3 3/8" bolts and is super sturdy.
Old Oct 26, 2009 | 07:47 PM
  #118
Taac81's Avatar
Originally Posted by trd_style
one of my cheapest mods was LED in my climate control, auto shift knob, cigerette lighter, dome light, and turn signal light.
how'd you do that? i'm trying to get some light in there cuz its frustrating to know what to do when u can't see the controls in the dark. do you have any pictures?
Old Oct 26, 2009 | 09:15 PM
  #119
Blackbird's Avatar
My truck is used mainly to haul stuff around and light towing so no off-road related mods but for I did put a few el-cheapo mods into it -
* Bought some $3 worth of U bolts and welded them on both sides of the bed of the truck, now I have plenty of places to tie stuff down.
* Modded the front bumper by removing the bottom skirt and replacing it with a deeper cut air dam.
Measured an improvement of 2 MPG on average and much improved stbility at highway speeds.
Total cost $35.
* Put a nice aluminum shift knob, just a classic satin finish ball. Feel much nicer in my hand!
Free mod 'cause I already had the knob
Moti
Old Oct 26, 2009 | 09:21 PM
  #120
4Yoter's Avatar
I got a second front tow hook at a junk yard $5
Made a set of quick release door hinges $10
Removed running boards $1,000,000,000
