Old Mar 23, 2016, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Exterior Guides
Print Wikipost
Show us your best cheap mods!
Old Sep 4, 2010 | 07:34 PM
  #441
Teuf's Avatar
Pass what, you mean someone told you you can't put something in your truck, you lost me? Explain. Thanks
Old Sep 5, 2010 | 12:38 AM
  #442
aa1911's Avatar
sweet, a rolling fridge, how handy.... now I don't have to drink warm beer on my way to work!
backup lights I put in today work good, didn't go driving yet but tried them out in my yard; they definitely help but are not overwhelming.... If they had full current they would probably be twice as bright. Want to get some LED replacement bulbs for the orginal lights; it is nice to see what's behind you in the dark!
Not a bad deal for $23 in cheap lights
Old Sep 7, 2010 | 10:41 AM
  #443
maistroyoda's Avatar
Here's one of the cheapest and best mods I've done for those of you that haven't seen it!
https://www.yotatech.com/forums/f114...t-nice-197014/
Old Sep 7, 2010 | 08:31 PM
  #444
irab88's Avatar
Originally Posted by aa1911
...I measured the power at the back up lights and it was only 9.95 VDC so losing some of their effectiveness right from the start but didn't feel like running a hot wire all the way from the battery so I just tapped directly into the existing backup bulbs. the LEDs don't draw very much power anyway, and they're cheap crap!
i ran a pos and neg 10 gauge (fused) from the battery, put a relay in, and used my "fog" lights in the rear. it works well, and now i have power for accessories later (maybe for a tbl on the cap i might get this week? )
Old Sep 11, 2010 | 05:20 PM
  #445
aa1911's Avatar
yeah, I will be running probably a 10g or two 12g hot wires to the back of my runner when I do that one; I will be putting 100w lights on it plus I just ordered a bunch of marine grade 12v sockets, some interior overhead lights and switches and a voltmeter to put in the back for camping, that will definitely need some juice.
got to try out the backup lights on my truck the other night, they work great; I can see much better even with the relatively weak LEDs (running on 9.95 volts)
Not really a mod but check out this thing I just made today, posted it here with some pics:
https://www.yotatech.com/forums/f5/w...l#post51547927
It's a mesh bag that runs across the back to hold gear. I can make more if anyone wants to buy something similar, I do custom sewing for a reasonable price; it's pretty handy, been on my to do list for a while
Old Sep 11, 2010 | 07:11 PM
  #446
irab88's Avatar
nice. i like that idea, keeps everything from sliding around
Old Sep 12, 2010 | 06:55 AM
  #447
RBX's Avatar
RBX
Put an extra courtesy light in where the rear wiper housing is located. Had to ground the light to the wiper motor since its wire to vehicle ground.
Resualt; open the the doors and two lights illuminate.
Unlock the tailgate, and the dome lights illuminate like the doors do.
Cost: $10 ...wire, 2-pin connector(for cab disconnect), bullet connectors, dome light form pick'n pull.
Tailgate courtesy light trigger 1stGen 4Runner:
Tap the green/red stripe wire on the Door Lock Control switch in the tailgate.
Run the tapped wire to the driver side kick and tap the courtesy light wire(i use bullet connectors for single wires so i can disconnect if needed)
Old Sep 13, 2010 | 04:09 PM
  #448
AssYriaNrocKer's Avatar
So finally did the Mag light and extinguisher mods!
Mag light-30$
brackets-2$
extinguisher-20$
Walmart!
The interior was dusty from the trail...very pleased with the outcome of these mods. Fun, easy, cheap and useful. If your thinking about it DO IT!
-RONI-
Old Sep 14, 2010 | 07:03 AM
  #449
irab88's Avatar
he's from down under, so my guess would be they have different rules and regs than us yanks
by the way, how's your floor insulation holding up?
Old Sep 16, 2010 | 03:05 PM
  #450
aa1911's Avatar
Here's a mod I'm about to do, I wanted to throw my wiring diagram out there for you guys to look at before I finished; I completed part of the harness and have all the stuff, wanted input/corrections from some of you electrical geniuses
It's 2 x 12v power outlets in the rear of my runner plus a voltage meter and some interior overhead lights. Also on the harness are hookups for roof rack driving lights, aux backup lights and on board air compressor.
https://www.yotatech.com/forums/f172...ts-ect-180625/
Also while I'm in there, I have some u-bolts I will be installing for some tie downs as in the first post on this thread plus some hooks for my fishing rod.
Take a look and tell me what you think, thanks!!
Old Sep 22, 2010 | 10:07 AM
  #451
aa1911's Avatar
Finished my mods on the 4runner, here's the link, didn't want to repost it:
https://www.yotatech.com/forums/f5/w...5/index11.html
has a bunch of pics and a new wiring diagram
12v outlets, voltmeter, LED interior lights and wiring for future mods (lights and OBA)
Old Sep 27, 2010 | 10:15 AM
  #452
4bangercraig's Avatar
My left rock slider was welded a liiiittle close to the body of the truck and after using it as a lift point a few times, it rattled horribly going down the road. Rattled isn't really even the word for it- it was more like grinding.
So I took some duck tape and folded it up until I had a nice thick cushion, lifted the body away from the slider with a crowbar, and wedged the tape in right under the pinch. Now, there's nothing but sweet, sweet silence.
And the sound of an aerodynamic nightmare careening down the freeway.
Old Sep 27, 2010 | 10:44 AM
  #453
grant526's Avatar
After a trip through the Rubicon my sliders started touching the pinch weld too. So I slid a screw driver in there and "adjusted" the pinch weld accordingly with a hammer. . . No more contact or noise
Old Sep 28, 2010 | 01:18 PM
  #454
BeenYota's Avatar
Originally Posted by streetlancer
Red out tail lights= $4
I'm gonna do it to the originals to restore them.
Although it looks as if you took Taco Clears and painted them. What was your method of getting the stock tails restored? Anybody think sanding and clear coating would restore to a glossy finish?
Old Sep 28, 2010 | 01:49 PM
  #455
higher state 4x4's Avatar
i mounted the rear seat belts,to the ceiling so i can strap my bass and my body board to the roof of the runner for extra space,two seat belts,so they can retract and unplug 0$ inside the runner like to the ceiling ,out of the elements and used the factory bolt holes just kinda flipped um
Old Sep 28, 2010 | 03:42 PM
  #456
89RUNNERFFD's Avatar
This was my first mod after I purchased the truck. Could not store my spare tire under truck. Bolts right to the roll bar.
Old Sep 30, 2010 | 08:39 AM
  #457
Any pics??
-RONI-
Old Oct 13, 2010 | 05:04 AM
  #458
1sennafan's Avatar
Thumbs up My Cheap-O Fender Flairs
Not $100's per side,
At Home-Depot get a roll of garage door 4" weather strip $12.95. A little sheet metal cut into 3/4" strips about 3' long, some self-taping screws and washers I already had and presto!
However with the Texas heat they tend to droop after a couple of summers.
Attached Thumbnails Show us your best cheap mods!-dscn1663.jpg   Show us your best cheap mods!-dscn1683.jpg
Old Oct 13, 2010 | 09:04 AM
  #459
Philbert's Avatar
That's really cool! I've been looking at a solution for relocating mine, since I have 32" tires and there's a ton of rubbing of the exhaust and my leaf springs. Was looking at swing out carriers but this is pretty neat!
Did you just fab that up yourself???
Old Oct 14, 2010 | 06:18 PM
  #460
1981 yota's Avatar
well i got my lights all wired up and workin
my tach in but not working yet
my cup holders in
