Rubber Mats for recovery?
Old May 27, 2010 | 07:54 AM
Billinsd's Avatar
What do you think of these types of rubber mats for recovery?
Or what do you use, carpet, rocks, etc?
Thanks
Bill
Old May 27, 2010 | 07:59 AM
xxxtreme22r's Avatar
not sure what your question is, but I've seen people use a t-shirt or other clothing over a winch cable to keep it from snapping back at either vehicle/people.
Old May 27, 2010 | 08:00 AM
874runnersr5's Avatar
I think he means to throw them under the tires.. in that case.. yeah they do work but to a certain point..
Old May 27, 2010 | 08:09 AM
waskillywabbit's Avatar
Winch and a Hi Lift would be better!
I wouldn't spend money on recovery floor mats.
Old May 27, 2010 | 08:15 AM
Billinsd's Avatar
Yes, I meant putting them under the tires.
Thanks
Bill
Old May 27, 2010 | 08:34 AM
scuba's Avatar
The only thing comparable I've ever seen comparable is the Xtrax mats
http://www.bushranger.com.au/x_trax_ii.php
They say there designed for maximum traction in sand, mud, and snow.
I don't know about you, but I don't spend enough time in either terrain to worry about rubber mats. If I'm in either of the 3 terrains, I'm sure I'll have someone to give me a tug with a strap.
Old May 28, 2010 | 07:37 AM
firemaniac's Avatar
Compact snow/ice, minor cant get traction to get moving type of stuck, mats like those can work wonders, it is amazing what just a pair of cheap floor mats can do for traction on ice.
In other conditions, other afore mentioned options may (probably will) be better.
Old Jun 5, 2010 | 10:39 PM
wyoming9's Avatar
Red face
Most times I tried using anything like that all that happens is they just get pulled out from under the tire in what direction they are going .
I have used a Hi-Lift jack to extract myself in the past
Old Jun 5, 2010 | 10:49 PM
firemaniac's Avatar
The key to the floor mats is slow as you go, spinning the tires usually turns theme into a projectile.
83yotastockR
11
Nov 10, 2015 06:54 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
irv
Sep 22, 2015 11:51 AM
skouba
Sep 14, 2015 06:58 AM
Pocoyota
Sep 8, 2015 02:41 PM
