rear drive shaft slip joint
OK, not sure if I even termed this right, any way I recently got my dual cases installed and had the rear shaft shortened. I am wondering if the rear shaft was shortened too much. Shaft was not done 'professionally' but the guy had the jigs etc. Driving the truck ('81 Toyota Trekker) at speed I don't get any abnormal vibrations etc.
But what concerns me is if there is enough contact on the rear slip joint?
Rear springs are fairly flexible (5" Trail-Gear)
Last edited by dropzone; Feb 10, 2009 at 12:14 PM. Reason: i am a non spelling ****
Looks normal to me. You're not seeing splines yet, so there's quite a ways to go.
In the end, the acid test is to put the axle at full droop and make sure the DS is still engaged on the splines.
hmm it does look a little short huh?
are you gonna be wheeling it much? theres the possibility of stripping the splines off although i ran one about like that for over a year when i was 16 (meaning i drove the hell out of it) and never had a problem
jacked it up with the high lift to check full droop per TC's suggestion and it extended further. so it looks like the guy is making me another shaft...
Could always add a spacer if a new shaft is going to run you too much:
- http://www.4crawler.com/4x4/ForSale/...ftSpacer.shtml
Generally want about 1" - 1.5" of compression travel from rest for a rear shaft, depending on how far you can compress the rear suspension.
other question I have: should the slip yoke be mounted at the Transfer Case instead of the Differential??
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
TNRunner88
Jul 1, 2015 08:00 PM
