Pull engine with transmission?
Old Jun 17, 2008 | 08:16 AM
83's Avatar
83
I need to pull my engine, all that's left is the block, head and everything's off. I will eventually be pulling the transmission, so is it easier to pull them together and wrestle them apart in the garage, or is it easier to separate them when one's still bolted in to the truck?
I've never done this before..I have pulled a tranny, but never rented a hoist and pulled the engine, so I'm a bit clueless here.
Once the engine's out, how heavy is it? Could two people get it wherever it needs to be moved to, or is it too heavy for that? Thanks!
Old Jun 17, 2008 | 08:29 AM
rdlsz24's Avatar
I am going to say it would be easier to pull them out still bolted together since you wouldn't have to get at the pita top bellhousing bolts. Once you get it out it helps to set it down on a dolly of some sort so you can move it around easily. You can make one out of plywood and 4 caster wheels.
Rob
Old Jun 17, 2008 | 08:51 AM
Lysmachia's Avatar
Yeah if you have a cherry picker it will prolly be easier to pull them both, otherwise you need to have a ton of wratchet extension at odd angled under neath the truck to get at the 2 top bell housing bolts!
Old Jun 17, 2008 | 08:55 AM
galloway's Avatar
ya i just pulled my engine and it was a pain
Old Jun 17, 2008 | 09:07 AM
nate9207's Avatar
i recently pulled my tranny and the top bellhousing bolts really arent as much of a pain as they say they are. a good 3/8 drive socket wrench, extensions (two 6" and one 3") and a couple swivels will get the job done. thats what i did and i worked out just fine. never pulled a motor but from what i know i'd pull the tranny and have it on a tranny jack, then get a cherrypicker to pull the motor out separate. you're gonna need em apart anyways cause i'd bet you're gonna redo all the clutch components. I'd put the motor back in and mount it first then bolt the tranny up. trust me, with as tight as it is in the engine bay, you won't want that tranny in the way when you're puttin the motor back in.
really any way of doin it is fine but thats what i'd do. either way its gonna be a pain in the @$$ haha
Old Jun 17, 2008 | 11:28 AM
83's Avatar
83
Yeah, the one thing that's certain is that it will be a pita! Ok, thanks everyone. Most of the engine is already out, just the block's left so there should be a bit more room to get at those bolts. I almost wonder if a few of us could get it without a hoist at this point.....but might as well rent the hoist.
Old Jun 17, 2008 | 11:57 AM
rdlsz24's Avatar
Rent or borrow the hoist just so you don't have any accidents. It's not a big engine but it's still heavy if it's the longblock. If it was just the shortblock it's not too bad, but the head adds another 50 pounds or so.
Rob
Old Jun 17, 2008 | 12:48 PM
Adam F's Avatar
Unless you have a good leveler, separate them. I tried to install my Chevy 350/toyota trans combo as a unit into my 4Runner, and it just diddnt work. The trans/transfer is soo long and heavy it tips backwards and is really hard to maneuver.
Getting it out might not be as bad. But without the leveler its just going to hit the ground as soon as you remove the trans from the mount.
Old Jun 17, 2008 | 02:29 PM
83's Avatar
83
Cool, thanks guys. I'll take them out one at a time instead of together.
Old Jun 19, 2008 | 05:58 AM
83's Avatar
83
Came out last night no problem, thanks everyone. Now....how do I get the flywheel bolts off since the thing just spins? Tried sticking a bar into the teeth to hold it still but no luck yet.
Old Jun 19, 2008 | 12:18 PM
Adam F's Avatar
I always use an impact gun. But if you dont have one, they do make a flywheel holding tool.
Old Jun 19, 2008 | 12:28 PM
83's Avatar
83
Hmm..ok thanks. But maybe I could make a flywheel holding tool...for cheap...we'll see. Thanks again.
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
andrewtexas123
Jul 14, 2015 04:29 AM
Jnkml
Jul 6, 2015 01:20 PM
