IFS vs SAS
Old Aug 2, 2009 | 01:03 PM
rusche's Avatar
IFS vs SAS
Kinzer and I were screwin around on my lunchbreak at work.
I need a solid axle
Old Aug 2, 2009 | 01:09 PM
Fink's Avatar
Moved to General Vehicle section.
He definitely has you beat on flex but both rigs are lookin' good.
I can't wait to get my '85 flexin' on the new OME stuff soon.
Fink
Old Aug 2, 2009 | 04:52 PM
tc's Avatar
tc
Looks to me like you both got "over" the same obstacle.
Old Aug 2, 2009 | 05:16 PM
[N8]'s Avatar
Only diff I see is your rear driver is off the ground. That's why you have the aussie, right
Old Aug 2, 2009 | 05:27 PM
RMA's Avatar
RMA
I like the way you think TC...
Old Aug 6, 2009 | 08:04 PM
Ron Helmuth's Avatar
that is Solid Axle at left correct? I just want to be sure.
Is it safe to say that the IFS rig has slightly more ground clearance at the axle itself?
It appears the front diff hangs lower on the SAS rig. Perhaps it is just the angle.
Old Aug 6, 2009 | 08:15 PM
Plumbrbob's Avatar
ifs has more ground clearance at the diff, but the sas rig has more flex making it more stable in super off camber situtaions
Old Aug 6, 2009 | 08:29 PM
tc's Avatar
tc
Neither of these are totally true.
IFS has more clearance at ride height or when the suspension is drooped, but less when the suspension is compressed. One of the biggest advantages to a SFA for rock crawling is that the clearance is constant - when the tire goes up the obstacle, so does the diff.
MANY solid front axle rigs are LESS stable on off-camber situations due to soft springs and a higher COG. Many things come to play in this equation and the axle type is one of the most minor ones. Track width, COG height, and shock/spring setup are way more important.
Old Aug 6, 2009 | 08:40 PM
Plumbrbob's Avatar
I beg to differ
my ifs rig did not have a dif hanging and i do not ever recall ever getting hung up on the front axlle components like i do with my SFA rig I have now.
I agree when the ifs rigs suspension is compressed the clearances are lessoned
I do not agree with the stabilty debate I have seen many ifs rigs on there side or on there top including mine on mild obstacles and I have never seen an ifs rig that can play in this rock garden
Old Aug 6, 2009 | 09:15 PM
scuba's Avatar
Im starting a flex picture thread..
Old Aug 6, 2009 | 09:36 PM
toyota4x4907's Avatar
I'm pretty sure there is at least one, Scoobs.
Old Aug 6, 2009 | 09:39 PM
scuba's Avatar
Well I already made it
Old Aug 6, 2009 | 09:44 PM
Well now for sure there is at least one
but no theriously I remember one....oh wellz.
Old Aug 6, 2009 | 09:45 PM
scuba's Avatar
I couldnt find one touched in the last 3 years... didnt go further back then that..
Old Aug 6, 2009 | 09:57 PM
crazy.......
I could have sworn there was one started in the time I have been a member, not even a year.
Old Aug 6, 2009 | 10:01 PM
904_runner's Avatar
SEEEEEEEEEEEAAAAAAAAAAAAAARRRRRRRRRRRCCCCCCCCCCCCH HHHHHHHHHHHHH
https://www.yotatech.com/forums/f123...-shots-105166/
https://www.yotatech.com/forums/f116...-warned-88708/
https://www.yotatech.com/forums/f116...-sucks-160130/
Old Aug 7, 2009 | 06:43 AM
tc's Avatar
tc
If it was closer, I would show you at least one IFS rig that would go through there ...
Old Aug 7, 2009 | 07:12 AM
scuba's Avatar
Hell I would try it...
83yotastockR
11
Nov 10, 2015 06:54 AM
dirk89
Oct 1, 2015 05:15 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
