help clear my mind
Old Jul 20, 2007 | 07:54 PM
SR5's Avatar
SR5
help clear my mind
i installed low profile bump stops and im worried that if fully flexed it could hurt my suspension
Old Jul 20, 2007 | 08:11 PM
Kaleb's Avatar
Then put in longer bump stops...
Old Jul 20, 2007 | 08:12 PM
drew303's Avatar
If you have balljoint spacers up front... engage the front end and spin the wheel, see if the cv halfshafts bind.. if they do, well you have a problem =)
if thats the case 4crawler has a differential lowering kit (1")
Old Jul 21, 2007 | 10:56 AM
SR5's Avatar
SR5
No thats not what i mean.
I just put low profile bump stop and i am WONDERING if it will hurt my suspension if i will fully flex.
Old Jul 21, 2007 | 11:06 AM
Elvota's Avatar
If it will hurt your torsion bars under full flex...?
Old Jul 21, 2007 | 12:17 PM
SR5's Avatar
SR5
no
let me try to make this a litte bit clear
i am woundering by putting on low profile bump stops (in the front) if that extra 1" of flex will hurt my shocks
because the stock ones were the size for a reason, right?
Old Jul 21, 2007 | 03:38 PM
MudHippy's Avatar
Now that's a possibility. I'm not sure, hadn't thought about it really. Maybe you want a shock that is 1" or so longer to be sure? I have shaved bumpstops but AM shocks, stock length supposedly, and they seem fine FWIW.
Old Jul 22, 2007 | 10:21 AM
thook's Avatar
Anytime you bottom out a shock, it's not good for it. You'll just have to determine if the shock is being fully compressed when you're wheel is fully stuffed.
ashamsuddin
17
Jul 22, 2024 03:59 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
charlie_fong
Sep 27, 2015 10:06 PM
