drain plug seepage
Old Apr 20, 2008 | 04:29 PM
rowdy235's Avatar
drain plug seepage
Okay, heres the story- back when i was not using it my cousin drove my truck. He got the oil changed (which is good), but he did it at jiffylube (bad). I wasn't too mad until he told me they put the drain plug on with an impact wrench.
So I dreaded the day I'd have to change it. As I expected, it took a 18" breaker bar to get the plug out. Rest of the change went OK. When I tightened the plug down I did like 3/4 turn past snug, I'm confident its in good. Now I get a couple drips every night; and I don't feel comfortable tightening any more.
So, should I get a new plug next oil change?
Old Apr 20, 2008 | 04:41 PM
becaron's Avatar
How do the threads look? on the plug? on the pan?
Are you using a plug gasket?
Old Apr 20, 2008 | 05:22 PM
OSU4Runner's Avatar
Replace the plug and rubber O-Ring. Also check the threads on the oil pan.
Old Apr 20, 2008 | 07:25 PM
rowdy235's Avatar
It didn't look like any threads were damaged. Can I get a new plug from the dealer?
Old Apr 21, 2008 | 12:09 AM
CyMoN's Avatar
get a plug at napa with the magnet on it.
Old Apr 21, 2008 | 06:09 AM
dirtoyboy's Avatar
Go to Jiffy Lube. Tell them how incompetent they are. Then make them fix it!
Old Apr 21, 2008 | 09:30 AM
rowdy235's Avatar
^^ lol tried it, they gave me a ton of paperwork which I filled out and sent in, about 3 months ago.
Old Apr 21, 2008 | 09:38 AM
dirtoyboy's Avatar
dang..well there has to be another way! Go up and talk to the manager or call the district manager....park the truck in front of the store with a big sign...that usually works if nothing else does.
Hell, I'm getting angry over here for ya
Old Apr 22, 2008 | 03:27 PM
rowdy235's Avatar
^ thanks but its water under the bridge. I picked up a new plug at the toyota dealer, talked to the mechanic, he said after a lot of changes (340,000 miles worth maybe), he said the plug gasket just wears out. He mentioned how on his cars every 5 changes he replaces the plug. Plug was only like $3.47, so we'll see the next time 3000 miles rolls around.
Old Apr 23, 2008 | 07:05 AM
dirtoyboy's Avatar
aye i thought you actually stripped the plug......yea i change those metal gaskets maybe once or twice a year
Old Apr 26, 2008 | 07:35 AM
deserttoy84's Avatar
just put a fiber washer on and it wont leak. dont use any type of metal washer they dont ever work on 22r.
Old Apr 26, 2008 | 05:10 PM
rowdy235's Avatar
^ noted, thanks
80Truck
Oct 12, 2025 07:25 PM
Blamalam
Mar 12, 2022 07:34 AM
kcaudill
Jul 20, 2015 12:06 PM
daddio
Jul 18, 2015 10:20 AM
msane99
Jul 17, 2015 10:13 AM
