Replacing timing cover Q's
Old Apr 26, 2008 | 06:33 PM
trailblazr81's Avatar
Im replacing the front crank oil seal and I was thinking of also replacing the timing cover gasket. Got a bad oil leak in front. Is it as simple as Im hoping? Just remove water pump and then un bolt timing cover? I hope.
Old Apr 26, 2008 | 06:51 PM
aquaprice's Avatar
Not really that simple on my 81 22R. I pulled the valve cover and distributor to take the cover off. If you are in there replace the timing chain.
Old Apr 26, 2008 | 08:09 PM
Well the supposed reason for the leak was the previous owner replaced the timing chain and did a half azz job puting stuff back on and now it leaks. So I'm hoping the chain is good.
Ichneumon
Sep 27, 2015 04:21 PM
puddlepirate
Jun 30, 2015 05:08 PM
serenity03k64
Jun 27, 2015 07:59 AM
marcusSRG
Jun 27, 2015 07:13 AM
Badger62811
Jun 26, 2015 09:26 PM
