Did I Hurt The Clutch Doing This?
Old Mar 19, 2009 | 03:06 PM
BT17R's Avatar
Since Day 1 (two years ago) my FJC clutch had a slight shudder, 2-3 pulses, when accelerating gently from a standstill. It was most noticeable after sitting all night, less so after the first drive of the day.
A shadetree mechanic friend suggested I smooth out the clutch/pp surface by revving to 3,500 rpm or so and easing out the clutch in 2Hi, allowing some slip until fully engaged. So I went to the base of a steep hill and tried it. The 1GR had enough torque to accelerate smartly even in 2nd, I let my foot off the clutch pedal completely in about 1-2 sec and then the engine headed toward redline, never fully engaging the clutch, so I eased off the throttle until hooked up.
I noticed an improvement right away, so tried it again. And again. Altogether three times and the problem is 90% cured.
I resorted to this method b/c the FJ wouldn't duplicate the shudder at the dealership, of course. My dealer was willing to replace the clutch under warranty, but I really didn't want it opened up, possibly creating other issues.
So, good or bad advice from my friend, and any long-term effects to consider?
Old Mar 19, 2009 | 03:50 PM
vital22re's Avatar
totally a bro
well.. your clutch life just got shorter big time. If the dealer was willing to replace it, then have them do it. I really dont think it would creat other issues, considering its still under warrenty the dealer would have to deal with it any ways.
Old Mar 19, 2009 | 03:52 PM
scuba's Avatar
X2...
Old Mar 19, 2009 | 03:55 PM
vic.kulla's Avatar
if it is under warranty let the dealership do it. usually if they break something, it will be covered
claudebadly's Avatar
i concure with vital. its warrenty work
Old Mar 19, 2009 | 04:42 PM
neoworm0's Avatar
?????? Your dealer was going to replace the clutch under warranty and as an alternative solution you decided to ride the hell out of it.
A: Give your head a shake.
B: Go slap your friend
C: Take your truck back to the dealer and see if they will still replace it under warranty.
nuff said.
Old Mar 19, 2009 | 07:07 PM
BT17R's Avatar
Shoulda asked here first. My bud was convincing talking about smoothing out the high/low points and whatnot.
Now I'm worried that when the dealer gets inside they'll see signs of heat stress and claim abuse.
I have to say the "fix" worked. Too bad the patient's life was shortened.
Old Mar 19, 2009 | 07:30 PM
neoworm0's Avatar
Just be adamant that there was a problem with it from the get go. Regardless of what you've done to it since it was never right. Don't take any crap.
Old Mar 20, 2009 | 10:32 PM
Adam F's Avatar
c: Take your truck back to the dealer and see if they will still replace it under warranty.
Nuff said.
agreed
smilen724
13
Nov 8, 2015 04:11 PM
voiddweller
Oct 2, 2015 07:47 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
