Cutting the top off Junkyard
Old Mar 18, 2009 | 09:58 AM
Outsane's Avatar
Any other alternatives to using a Battery powered Sawzall
to cut the roof off of a 4runner?
thanks..
Old Mar 18, 2009 | 10:06 AM
NicCantDecide's Avatar
bare hands?
Jaws of Life?
teeth?
Old Mar 18, 2009 | 10:07 AM
algranger's Avatar
Jigsaw gives a nice clean cut.
Old Mar 18, 2009 | 10:19 AM
Outsane's Avatar
anything that I can pick up at home depot for cheap and does not require a plug?
Old Mar 18, 2009 | 10:40 AM
zlathim's Avatar
Hacksaw
Old Mar 18, 2009 | 12:35 PM
DeathCougar's Avatar
You can use a torch, but they tend to be very dangerous.
We use cordless sawzalls here to do cuts for body shops (I work for a wrecking yard) and it is by far the fastest, and safest method. It tends to be spendy since they blades are so much money, but its worth it.
Cordless saws are going to run you $125-$250 depending on quality. We use the DeWalt saws, and they seem to hold up the best for the value.
Old Mar 18, 2009 | 12:38 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
pair of sissors? Whats wrong with a sawzall?
Old Mar 18, 2009 | 01:08 PM
I'm not a fan of battery powered tools, but if you have to get one I'd say go DeWalt or Makita. Sawzall's quick and easy, jigsaw would probably make for a cleaner cut but will take more time.
I'd say don't bother with the torch, you'll probably put the truck up in flames if its like most cars in a junkyard.
Old Mar 18, 2009 | 02:09 PM
firemaniac's Avatar
At the Fire station I grab the speedway cutters (part of the jaws of life set) for the "A" and "B" pillars, and a cordless sawzall for the rest (usually the windshield's top edge) however in training I have had good results using only the sawzall, cutting metal will take some time (I cut the glass in a rescue as a sawzall blows through it faster than the metal). and as for brand Dewalt is what we run on the Engines here, for a blade we carry both metal (higher teeth per inch) and Destruction (medium teeth per inch), the destruction will handle everything, but will not be the best at one or the other.
If you don't want to spend new prices and only have one job in mind for it, check pawn shops in your area. Look for one with a name you would trust, and has charger, and batteries with it.
Also if the JY is letting you cut it off, find out if you can park next to it, that would allow you to run a small generator or an inventor from the truck, and a less expensive corded sawzall, granted the inventor would have to be of the appropriate wattage to run it
Old Mar 18, 2009 | 03:23 PM
gary96360's Avatar
wont the guys at junkyard let u use their torch?
Old Mar 18, 2009 | 03:29 PM
A yard usually won't let you even make the cut yourself, for liability reasons.
Old Mar 18, 2009 | 03:30 PM
Dan.3's Avatar
what about dental floss??? sorry could resist. If you dont need a sawzaw to often you get get a ryobi one for cheap. For the price and what you seem to be needing it for it should work fine. I had a 12v ryobi drill to have around the house and the battery help up for about 4 years. Not bad for $40. I would get ryobi for everyday use. I used it a total of 20 times so far if that
Old Mar 21, 2009 | 06:06 AM
Outsane's Avatar
cuts made...
There was a top at the pick your parts where i would have done the cut and gotten away for $60...
but I had to go to a place where they pull it.. $150 for a rust free roof with the pop up sunroof... but its busted..
thanks
theking11863
Mar 19, 2016 09:36 PM
Lochsa
Aug 2, 2015 02:51 PM
ty1er
Aug 1, 2015 11:53 PM
TDonkey
Jul 26, 2015 10:14 AM
crashburnoveride
Jul 10, 2015 06:39 AM
