Aesthetic Help
Old Jul 25, 2012 | 10:30 AM
KnightFiyah's Avatar
Aesthetic Help
I'm trying to clean up these kind of less than pleasing areas of my truck and I might need some suggestions.
For the mirror's black paint marks, I was thinking just some basic Rustoleum black paint to coat them.
For the white peeling sticker and the partly torn off "Toyota" black decal though, I wasn't sure the best way to go about removing them cheap and easy. I don't want to damage my windshield or paint so any help there would be great!
Old Jul 25, 2012 | 11:22 AM
85TurboRunner's Avatar
For the mirrors I'd say spray paint, for the sticker on the window I'd use a razor and the toyota sticker use a heat gun to get it soft then just peel it off.
Old Jul 25, 2012 | 06:25 PM
Ahh heat gun...good idea...hopefully I can manage to get the sticker off without damaging the windshield with the razor lol. Thanks Turbo!
Old Jul 25, 2012 | 08:31 PM
Discombobulated's Avatar
When I blade stuff off of glass I lubricate with glass cleaner while doing it, when your done you can use a shop vac crevice tool to get the flakes out.
Old Jul 26, 2012 | 07:30 AM
That's a good idea, I might try to stop by Ace on my way home from work.
Thanks for the tip.
Old Jul 26, 2012 | 08:17 AM
highonpottery's Avatar
use a plastic-specific paint on the plastic pieces or you'll be doing it again, and probably with more prep work the 2nd time.
on the actual mirror part that's faded, and since you're gonna be sanding to paint it anyways, you might even be able to entirely sand and buff that out since I'm assuming it's solid plastic vs the mirror base which looks like chipped paint. try a very low-abrasive, possibly even toothpaste like people use on plastic headlights.
Old Jul 26, 2012 | 10:26 AM
nothingbetter's Avatar
to make your life easier with the mirror, take it off first, and then do the work. Don't cut any corners while prepping it.
Old Jul 26, 2012 | 11:03 AM
When you pull the mirror be careful when prying off the inside piece to get to the bolts, if you have a trim removal tool that will work best, if not a thin butter knife will work. You don't want to pry it off with your fingers or the little ball tab will break.
Old Jul 26, 2012 | 11:44 AM
Thanks for the advice guys. Lots more to plan for than I had originally anticipated haha but that's alright. I want it done right.
mreagen
Sep 8, 2015 03:46 PM
Sandls
Mar 26, 2015 06:28 AM
4runnerJones
Feb 8, 2015 12:58 PM
vanhuette
Feb 1, 2015 11:17 AM
NewToYota
Nov 27, 2014 12:27 PM
