why does my new clutch chatter at me?
My clutch chatters when idling or in gear.. only time it doesnt chatter is when i depress the clutch. It stops chattering when the clutch is depressed about an inch. The clutch begins engaging at just under half way up. This is a brand new clutch on a 95 4runner with the 3.0 v6. It is a centerforce dual friction clutch. When I run my truck it smells like burning clutch. Ive got about 2500 miles on the new clutch since it was installed.
Thanks in advance, I appriciate it.
yea i had them replace everything new. Im thinkin they put the wrong size throwout bearing in, i called centerforce and he told me thats what it sounds like, apparently the clutch i have takes a smaller version... ultimately i think ill end up having to pull it apart to see what it looks like. should be interesting 8) and will be a first for me. Ill post some pics when i get to it... heres what happened last time i did something for the first time on my new truck...
https://www.yotatech.com/forums/f88/...e-yota-183948/
Disk in backwards or you have hot spots (hardened areas of the flywheel or pressure plate). This can be seen after the clutch is broken down and inspected. I am putting a Centerfource 2 clutch in my jeep as I already have one in my 87 4Runner and I am very happy with it. My jeep is currently torn down in the carport being restored. I am getting ready today to set the engine and transmission in on a powder coated frame and new suspension.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
