Sponsored by: CARiD
why does my new clutch chatter at me?
Old Nov 16, 2009 | 08:51 AM
Hardstripe's Avatar
My clutch chatters when idling or in gear.. only time it doesnt chatter is when i depress the clutch. It stops chattering when the clutch is depressed about an inch. The clutch begins engaging at just under half way up. This is a brand new clutch on a 95 4runner with the 3.0 v6. It is a centerforce dual friction clutch. When I run my truck it smells like burning clutch. Ive got about 2500 miles on the new clutch since it was installed.
Thanks in advance, I appriciate it.
Old Nov 16, 2009 | 08:54 AM
91Toyota's Avatar
Did you have the flywheel resurfaced?
Old Nov 16, 2009 | 02:03 PM
eddieleephd's Avatar
X2 and as well did you get a new pressure plate?? and did you bleed your slave Cyl till it was clear to make sure there is no air in the lines and all is fresh??
Old Nov 16, 2009 | 03:16 PM
theAuthority's Avatar
User Requested Ban
because he never read this forum?
chances are it was installed backwards ... i've seen that happen.
Old Nov 16, 2009 | 05:49 PM
Hardstripe's Avatar
i didnt install it, the college students did it for free... lucky me.
Old Nov 16, 2009 | 08:59 PM
What you got against Centerforce??? I will repeat my question did you do a new pressure plate???
Old Nov 16, 2009 | 09:25 PM
Hardstripe's Avatar
yea i had them replace everything new. Im thinkin they put the wrong size throwout bearing in, i called centerforce and he told me thats what it sounds like, apparently the clutch i have takes a smaller version... ultimately i think ill end up having to pull it apart to see what it looks like. should be interesting 8) and will be a first for me. Ill post some pics when i get to it... heres what happened last time i did something for the first time on my new truck...
https://www.yotatech.com/forums/f88/...e-yota-183948/
Old Apr 29, 2010 | 07:31 AM
divedude's Avatar
Disk in backwards or you have hot spots (hardened areas of the flywheel or pressure plate). This can be seen after the clutch is broken down and inspected. I am putting a Centerfource 2 clutch in my jeep as I already have one in my 87 4Runner and I am very happy with it. My jeep is currently torn down in the carport being restored. I am getting ready today to set the engine and transmission in on a powder coated frame and new suspension.
Old Apr 30, 2010 | 04:08 AM
vital22re's Avatar
totally a bro
improper installation of pressure plate/clutch disk is my guess. Maybe presure plate wasn't torqued down right.
Old Apr 30, 2010 | 04:39 AM
iselloil's Avatar
Its in backwards
Old Apr 30, 2010 | 04:40 AM
xxxtreme22r's Avatar
if the college did it, I would take it back to them to do.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
