What is this tube on top of my radiator?
Can anyone tell me what this tube is for? Its the one that comes right off the top of the radiator. Here is a pic. (and i'm not talking about the overflow tube.)
that is the coolant FEED for the ct-20 turbo... Trust me! In the attached pic, you'll see where I had removed the outlet on the radiator and had the hole covered (with a nickel). I did so because my t3/t4 isn't water cooled.
http://i94.photobucket.com/albums/l9...3/IM006148.jpg
http://i94.photobucket.com/albums/l9...3/IM006379.jpg
p.s. - previous replies have made me realize just how much I've learned in the last few years. silly guys.
So what do I do with the line from the turbo that goes to the radiator if the new radiator doesn't have a port for it at the top. Can I make a port or maybe run it to the overflow tank instead since its a return and not a supply?
And thanks for the wise a$$ comment wyoming9. Some of us haven't yet learned what others may have, hence the reason that we are all here. If you are not here to share the things that YOU know, then just stay your a$s in the woods where you belong.
I did not mean for it to be a wise ass comment. I am sorry if you took it that way.
In my case with a new radiator I just installed a new nipple in the same spot.
Yes Indeed I would prefer to stay in the woods thank you for that any way
Tee it into something on the low-pressure side of the water pump, like the return from the heater core, or the upper rad hose. You COULD tap into the lower rad hose, or lower part of the radiator, but you won't give that coolant from the turbo a chance to be cooled.
jasonty
41
Dec 23, 2018 01:00 PM
Road Bull
Oct 10, 2015 04:55 PM
TJWilly
Jul 31, 2015 02:05 PM
