Sponsored by: CARiD
What is this tube on top of my radiator?
Old Jun 6, 2010 | 02:07 PM
Double D's Avatar
Can anyone tell me what this tube is for? Its the one that comes right off the top of the radiator. Here is a pic. (and i'm not talking about the overflow tube.)
Old Jun 6, 2010 | 02:16 PM
wii_tarded's Avatar
That's an overflow tube that should run to a resevior.
Old Jun 6, 2010 | 02:32 PM
toyota4x4907's Avatar
Well it would be nice to know what engine its on...is that a 22r-te?
Old Jun 6, 2010 | 02:59 PM
MaK92-4RnR's Avatar
i think it might be a 22rte since the distributor is small and the set up looks different than a normal 22re
Old Jun 6, 2010 | 03:08 PM
Double D's Avatar
Sorry. 22rte.
Old Jun 6, 2010 | 03:10 PM
MaK92-4RnR's Avatar
whats the line go to?
Old Jun 6, 2010 | 03:17 PM
annoyingrob's Avatar
The turbocharger is water cooled. That's the coolant return line for the turbo. Not a lot of turbo truck around, most people probably have never seen that line
Old Jun 6, 2010 | 03:37 PM
i have but not not person
Old Jun 7, 2010 | 05:59 PM
nhughes's Avatar
Exclamation
that is the coolant FEED for the ct-20 turbo... Trust me! In the attached pic, you'll see where I had removed the outlet on the radiator and had the hole covered (with a nickel). I did so because my t3/t4 isn't water cooled.
http://i94.photobucket.com/albums/l9...3/IM006148.jpg
http://i94.photobucket.com/albums/l9...3/IM006379.jpg
p.s. - previous replies have made me realize just how much I've learned in the last few years. silly guys.
Old Jun 7, 2010 | 10:49 PM
wyoming9's Avatar
Red face
Yes indeed that is the coolant line to the Turbo.
I can`t see how you couldn`t see that just by looking.
Such is things.
Old Jun 11, 2010 | 06:21 PM
If it was the feed, how would coolant ever travel through it? It sits at the top of the rad where there's little/no coolant, and nothing pushing the coolant through. The feed comes from the water pump.
Old Jun 14, 2010 | 11:55 AM
Double D's Avatar
So what do I do with the line from the turbo that goes to the radiator if the new radiator doesn't have a port for it at the top. Can I make a port or maybe run it to the overflow tank instead since its a return and not a supply?
And thanks for the wise a$$ comment wyoming9. Some of us haven't yet learned what others may have, hence the reason that we are all here. If you are not here to share the things that YOU know, then just stay your a$s in the woods where you belong.
Old Jun 14, 2010 | 03:04 PM
wyoming9's Avatar
Red face
I did not mean for it to be a wise ass comment. I am sorry if you took it that way.
In my case with a new radiator I just installed a new nipple in the same spot.
Yes Indeed I would prefer to stay in the woods thank you for that any way
Old Jun 18, 2010 | 06:26 PM
Don't put it into the overflow. If you do that, then it'll pump all of your coolant into the overflow, and spill out. Overflow only fills up when pressure builds in your radiator, and pushes the rad cap up, and into the overflow.
Tee it into something on the low-pressure side of the water pump, like the return from the heater core, or the upper rad hose. You COULD tap into the lower rad hose, or lower part of the radiator, but you won't give that coolant from the turbo a chance to be cooled.
Old Jun 18, 2010 | 09:54 PM
sk8r89's Avatar
you could probably cut that nipple off and take it to a radiator shop and im sure they could cut a hole and braze it in there pretty cheap!
80Truck
Oct 12, 2025 07:25 PM
jasonty
41
Dec 23, 2018 01:00 PM
Road Bull
Oct 10, 2015 04:55 PM
TJWilly
Jul 31, 2015 02:05 PM
adammtb
Jul 27, 2015 11:57 AM
