Sponsored by: CARiD
Vibration issues
Old Jul 21, 2008 | 04:45 PM
buckz6319's Avatar
Question Vibration issues
Old Jul 21, 2008 | 08:12 PM
bigarms23's Avatar
did you have the driveshaft rebalanced when you changed ujoints and and how are your yokes?
Old Jul 21, 2008 | 08:14 PM
4Crawler's Avatar
Check all the parts of the shaft and the t-case and pinion flanges for play. Also check the phasing of the u-joints:
- http://www.4crawler.com/4x4/CheapTri....shtml#Phasing
And if that is all OK, try some of the tips listed below:
- http://www.4crawler.com/4x4/CheapTri...FixingProblems
Old Jul 21, 2008 | 08:19 PM
TOYOTA 1's Avatar
ive never had to have my d-shaft rebalanced after changing a u-joint..
just phase it and its good to go.
Old Jul 22, 2008 | 02:41 AM
buckz6319's Avatar
Old Jul 22, 2008 | 02:45 AM
buckz6319's Avatar
Old Jul 22, 2008 | 02:37 PM
buckz6319's Avatar
Last edited by buckz6319; May 20, 2010 at 05:10 PM. Reason: the front bumper, tires & rims, steering wheel, brake pedal,floor board shifter all vibrate when sitting at idle
Old Jul 22, 2008 | 02:40 PM
904_runner's Avatar
Are the tires balanced? Just wondering
Old Jul 22, 2008 | 03:04 PM
buckz6319's Avatar
Old Jul 22, 2008 | 03:05 PM
904_runner's Avatar
Nah, we will figure it out! What about tranny mounts/etc..
Old Jul 22, 2008 | 03:39 PM
buckz6319's Avatar
Old Jul 22, 2008 | 03:46 PM
ozziesironmanoffroad's Avatar
did you check the oil in the rear diff? check for metal shavings. also, get a friend , put the truck up on jack stands, and have your friend get it up to the vibrating speed, and it sounds bad enough that you should be able to see something wobbling. id try that. it sounds like something with your drivetrain, not your engine, since it doesnt vibrate in place. just be careful, and USE JACK STANDS DO NOT RELY ON A JACK. JACKSTANDS ALL AROUND! BE CAREFUL! these trucks seem to like to hurt us.
Old Jul 22, 2008 | 03:57 PM
buckz6319's Avatar
Old Jul 22, 2008 | 04:02 PM
maybe, but check anyway. doesnt hurt. also lift it up on jackstands and have someone drive it up to the speed where it vibrates, and keep it there and look for a wobble. maybe you will see it, maybe not. just for godsakes be careful.
Old Jul 22, 2008 | 04:24 PM
buckz6319's Avatar
Old Jul 22, 2008 | 07:44 PM
dbcx's Avatar
Originally Posted by buckz6319
ok cool....I'll try to do that somehow this weekend in the meantime I'll just keep on trucking I hope that this thing doesn't strand me in this Atlanta Traffic but if it does then maybe my problem will be found
im here in atlanta too. What do your tires look like maybe you need to rotate, may not hurt to rebalance. If your starting to cup or havent rotated them that can cause some issues. Atlanta traffic kicks ass
Old Jul 23, 2008 | 02:31 AM
buckz6319's Avatar
Old Jul 23, 2008 | 04:40 PM
buckz6319's Avatar
Old Jul 24, 2008 | 03:59 PM
buckz6319's Avatar
Old Jul 24, 2008 | 04:57 PM
904_runner's Avatar
well i guess you found it. I wouldn't have even thought to check there because i swaped out for some manual hubs so my cv joints don't move when unlocked. Get those fixed, take it for a test drive and see if its gone!
