Sponsored by: CARiD
Vibration issues
Old Apr 1, 2010 | 04:33 AM
  #41
hilux1026's Avatar
is your cv loose in the spindle bearings?? grab the cv were it goes through the hub and see if you can move it
Old Apr 1, 2010 | 09:18 PM
  #42
Pumpkinyota's Avatar
Originally Posted by shancerlelby
tryed the nut that holds the output shaft into the rear of your transfer case? the large nut inside backed off to where it was finger tight on mine. worth a look. you just have to drop the front of the shaft out.
This is probably a winner. Also check the bolts from the driveline to the output shaft, these frequently loosen up and cause the vibration that you are talking about. If this were a problem, you would especially notice it if the truck were rolling with the truck in gear and the motor under load, it would probably diminsh slightly if youput the vehicle in neutral while rolling.
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
crammit442
7
Nov 29, 2017 12:30 PM
raptor510
Aug 19, 2015 02:15 PM
rjtrials
Aug 6, 2015 07:25 PM
