Sponsored by: CARiD
Vibration issues
Old Jul 25, 2008 | 02:39 AM
buckz6319's Avatar
Old Jul 26, 2008 | 12:14 PM
buckz6319's Avatar
Old Jul 27, 2008 | 02:50 PM
904_runner's Avatar
sorry, don't know anymore, maybe the other side?
Search wheel bearings, i really don't know much about them.
Good luck!
Old Jul 27, 2008 | 07:26 PM
shancerlelby's Avatar
tryed the nut that holds the output shaft into the rear of your transfer case? the large nut inside backed off to where it was finger tight on mine. worth a look. you just have to drop the front of the shaft out.
Old Jul 28, 2008 | 02:29 PM
  #25
buckz6319's Avatar
Old Jul 31, 2008 | 01:07 AM
  #26
TrikeKid's Avatar
I tightened the flange nut on my truck up chasing the same type of vibration. New U-joints helped some, but it's still there. The flange on my t-case will actually move side to side though, one of those side effects of having 260 thousand miles, my trans is trashed and my case needs rebuilt. Have you tried simply greasing the u-joints and slip yokes up? if not, it's a good place to start and it's usually something people neglect.
Old Aug 2, 2008 | 01:25 PM
  #27
buckz6319's Avatar
Old Aug 3, 2008 | 10:14 PM
  #28
4Crawler's Avatar
Technically, the pinion and t-case flange nuts are one time use parts. But I have re-used them if they are in good shape and I am able to get a good stake on the nut:
- http://www.4crawler.com/4x4/CheapTri...ionSeal/8.html
Old Aug 4, 2008 | 02:36 AM
  #29
buckz6319's Avatar
Old Jan 15, 2009 | 08:12 AM
  #30
buckz6319's Avatar
Old Jan 21, 2009 | 08:40 AM
  #31
buckz6319's Avatar
Arrow yet again another update
Old Feb 18, 2009 | 05:02 PM
  #32
boosteda9's Avatar
hey i am going therw the same thing right now.
i sold my 2nd gen to my sis becuz she smashed her crv into a tree and needed a car
anyway she drove doing to work one day then i drove it to school to change the oil and ever since she drove once i hit 30 mph it vribrats but when i let off the gass it goes away.
she told me she was doing 90 on the highway. soo with 33s its almost like 96.
i did replace the rear pion seal 2 months ago i am thinking about droping the drive shaft and maken sure that nut is tight..
i'll let you guys kno if it fixes it..
btw i got a wrangler now but i still miss my 2nd gen.
i just wunted the wrangler so i can drive around with the doors off and no roof
Old Feb 19, 2009 | 05:16 AM
  #33
boosteda9's Avatar
we today i got under my truck unbolted the drive shaft in the back and my cv joint is like shot there is alot of play in the drive shaft in the back where it bolts to the rear.
soo if any one has a link of how to replace i need it thankss
Old Feb 19, 2009 | 05:10 PM
  #34
buckz6319's Avatar
Old Feb 21, 2009 | 03:28 PM
  #35
buckz6319's Avatar
Old Feb 22, 2009 | 05:25 AM
  #36
95VZE's Avatar
I have been having the same problem with the vibration you talk about through the shifter area at 35-40mph and under load or neutral, etc, etc, so I searched and read all your history on it. My 4Runner has 165,000 and the vibration/chatter has been getting steadily louder over a period of 3-6 months.
I just took it to Toyota dealer and they replaced the entire drive shaft assembly and re-torqued the flange bolts and that completely eliminated the problem.
Hope that helps.
Old Feb 22, 2009 | 05:57 AM
  #37
buckz6319's Avatar
Old Mar 31, 2010 | 11:40 PM
  #38
SDMF's Avatar
I'm having the same problem with my 96' Tacoma. Toyota told me that I have a bent fwd drive shaft, but the wouldn't tell me how they came to that conclusion. I'm assuming they were just trying to get more money out of me. I was told that my transmission mounts were loose. Did you try tightening them? I know you said you insp. them.
Mine starts to vibrate around 30-35mph and around 55 it's horrible. Like you said, when I let of the gas around 55-60 the vibration is at it's worse. I'll let you know if I ever figure anything out.
Old Apr 1, 2010 | 02:11 AM
  #39
crawyota's Avatar
From: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
i just put mine in the shop for the same thing , but when i had to get the state insp. done a few weeks ago , they told me that i needed to have the fr. pass. side axle replaced. since the cv boot was ripped. but i too was getting the whole vibration from 35 mph . i had the same problem a few years ago , and was fixed with the axle replacement. wow this seems like a problem on the 95............
Old Apr 1, 2010 | 02:17 AM
  #40
buckz6319's Avatar
