solenoid
solenoid
Hey my 1994 pick up will not start and im pretty sure that its the solenoid. I want to change it myself and I am wondering if there is any thing I should know or is it as simple as it looks?
when you say solenoid you mean starter solenoid...correct..?
4crawler makes starter solenoid contact (likely to be the problem) that you can easily change out and keep your Aisin unit...
The ones from Vatozone arent to be trusted..
If it was the solenoid you would hear a click.
I would check ALL the connections, take off the loose corrosion, and put some dielectric grease on them.
New batteries aren't always charged. Try charging it. Why did you get a new one?
Yeah all i hear is a click. BY new battery I mean a couple of months. I started it yesterday morning and it started fine. Then about an hour later i try to start it and nothing. Im confused about the different parts u guys are mentioning? so 4 crawler is a good brand??
Autozone-duralast=junk. Worked there for a few years, the quality is horrible on electrical. Id double check to make sure that you have 12 volts to the small wire that plugs into the starter when the key is turned to start. If you have 12 volts, than it sounds like a bad solenoid. If you hit 12 volts to the same connection on the starter, if the solenoid is good, it will click and the starter motor is shot. Just make sure its in neutral, if its in gear it will move!
Alright cool, Ill check that out. Do u have any suggestion on a cheap decent brand of solenoid if that turns out to be the problem?
I like to replace the whole starter, that way the solenoid and the motor are both warranteed and where I live the starter being replaced is so corroded that its useless. If your case is in nice shape and your on a budget, get the contact set and replace those, or if 125 bucks seems ok, just pick up a re man starter from napa or someone who is a local parts store. The solenoid itself is almost as much as a reman starter.
Here is a quick test you can do to see if the solenoid is the problem or not:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
and easy enough to fix the solenoid if that is the problem:
- http://www.4crawler.com/4x4/CheapTri...rter.shtml#Fix
