Sponsored by: CARiD
solenoid
Old Nov 5, 2008 | 08:24 AM
vincepower's Avatar
solenoid
Hey my 1994 pick up will not start and im pretty sure that its the solenoid. I want to change it myself and I am wondering if there is any thing I should know or is it as simple as it looks?
Old Nov 5, 2008 | 08:31 AM
22mr2's Avatar
its pretty cut and dry. R u sure its the solenoid? Click no turn? No noise at all?
Old Nov 5, 2008 | 08:41 AM
83's Avatar
83
Yeah make sure it's not the battery or even just corrosion on the battery terminals.
Old Nov 5, 2008 | 08:47 AM
vincepower's Avatar
Its a brand new battery. I just turn the key and nothing.
Old Nov 5, 2008 | 09:28 AM
scuba's Avatar
when you say solenoid you mean starter solenoid...correct..?
4crawler makes starter solenoid contact (likely to be the problem) that you can easily change out and keep your Aisin unit...
The ones from Vatozone arent to be trusted..
24Runna's Avatar
If it was the solenoid you would hear a click.
I would check ALL the connections, take off the loose corrosion, and put some dielectric grease on them.
New batteries aren't always charged. Try charging it. Why did you get a new one?
Old Nov 5, 2008 | 09:29 AM
24Runna's Avatar
Scuba, are you talking about the starters from Autozone?
Old Nov 5, 2008 | 09:35 AM
scuba's Avatar
Yes..And when I say not to be trusted i dont mean that in a horrible way..Many people have a firm beliefe in the Aisin electrical products, and they can easily be refurbished from home...
Old Nov 5, 2008 | 10:00 AM
vincepower's Avatar
Yeah all i hear is a click. BY new battery I mean a couple of months. I started it yesterday morning and it started fine. Then about an hour later i try to start it and nothing. Im confused about the different parts u guys are mentioning? so 4 crawler is a good brand??
Old Nov 5, 2008 | 10:06 AM
22mr2's Avatar
Autozone-duralast=junk. Worked there for a few years, the quality is horrible on electrical. Id double check to make sure that you have 12 volts to the small wire that plugs into the starter when the key is turned to start. If you have 12 volts, than it sounds like a bad solenoid. If you hit 12 volts to the same connection on the starter, if the solenoid is good, it will click and the starter motor is shot. Just make sure its in neutral, if its in gear it will move!
Old Nov 5, 2008 | 10:09 AM
22mr2's Avatar
4 crawler is the guy who sells the contacts in the solenoid that go bad alot. You can also just get a reman starter from a parts store(napa has decent starters)
Old Nov 5, 2008 | 10:24 AM
vincepower's Avatar
Alright cool, Ill check that out. Do u have any suggestion on a cheap decent brand of solenoid if that turns out to be the problem?
Old Nov 5, 2008 | 10:52 AM
22mr2's Avatar
I like to replace the whole starter, that way the solenoid and the motor are both warranteed and where I live the starter being replaced is so corroded that its useless. If your case is in nice shape and your on a budget, get the contact set and replace those, or if 125 bucks seems ok, just pick up a re man starter from napa or someone who is a local parts store. The solenoid itself is almost as much as a reman starter.
Old Nov 5, 2008 | 11:14 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
i have a pepboys starter and its been working 100% fine for the past 2 years...
Old Nov 5, 2008 | 11:55 AM
4Crawler's Avatar
Here is a quick test you can do to see if the solenoid is the problem or not:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
and easy enough to fix the solenoid if that is the problem:
- http://www.4crawler.com/4x4/CheapTri...rter.shtml#Fix
Old Nov 5, 2008 | 12:09 PM
scuba's Avatar
Can I have your aisin one ?
Old Nov 5, 2008 | 08:29 PM
vincepower's Avatar
Well I feel stupid. It was a bad connection with the batter. I tightened the nut maybe a quarter turn and thats all it took. Thanks for all of the help.
chuckross1957
Jun 28, 2019 10:19 PM
pickle6415
Oct 19, 2015 08:08 AM
toyhaulert100
Sep 24, 2015 07:55 PM
themightykhoner
Sep 18, 2015 02:28 AM
jgwerth
Jul 16, 2015 03:23 PM
