Sponsored by: CARiD
Shackles
Old Apr 5, 2010 | 08:22 PM
4Crawler's Avatar
Originally Posted by bryanchatfield
so i installed a rough country 3" lift, and i am wondering if i should get extended brake lines?
See if the brake lines still have some slack at full droop, if so, they are fine, it not get longer ones.
Also i want to get a little bit more lift, so if i do new shackles say 2" longer than stock what will that do for me?
About an inch of lift:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ
Will i have to get the extended brake lines?
See above, if you have less than 1" of slack in the lines now, you'll need longer ones with longer shackles.
Also i read somewhere that you can remount the brake mounts so that u dont have to buy longer brake lines, is that true?
Yes. you can cut the stock hard line brackets off the top of the frame and weld them on lower on the frame rail to gain a few inches.
Big Little Bear
230
Nov 13, 2023 11:42 AM
Redeth005
Jun 28, 2018 08:16 PM
Scottcrb
Mar 3, 2016 11:57 AM
oldblue
Sep 28, 2015 04:07 PM
sonorn67
Sep 19, 2015 05:39 PM
