Sponsored by: CARiD
SAS questions
Old Mar 24, 2010 | 08:05 PM
Muddrkid817's Avatar
SAS questions
Ok, first off i have read just about everything i can find regarding SAS kits around here and other forums on the net i.e. Marlin Crawler.
Questions:
1. Whats the best kit to use in your opinion? My truck is a daily driver (approx. 30 mile round trip commute)
2. best spring height? i am currently runnning 33's on a 5'' IFS lift with stock 4.11 gears. Im gonna keep the 33's until the wear away then go to 35's or 37's. i was thinking 4'' spring??
3. Front Driveshaft?? i have seen several square tube driveshafts but my truck is a daily driver, but im also a student so the budget is very limited ( so no pricey custom driveshafts)
i found this driveshaft on east coast gear supply's website: http://eastcoastgearsupply.com/i-133...shaft-kit.html any thoughts??
i would like for it to sit a few inches higher. im running a 4'' superlift ifs lift kit circa 1990 with 1.5'' bj spacers and 4.5'' rear blocks
Old Mar 24, 2010 | 08:10 PM
87hillbillyoter's Avatar
go to trail-gear.com. they have a good kit. also, if your gonna do it, do the 5 inch. its the same price
Old Mar 24, 2010 | 08:11 PM
dropzone's Avatar
Fossilized
budget tech:
63" chevy spring swap for the rear-->read this
Rears up front (RUF)--> read this
i would not recommend the 5" lift, I have it...too high. Keep your COG as low as possible
Old Mar 24, 2010 | 08:20 PM
thanks for the quick replies, im thinking about the 4'' kit for mine cuz 3'' seems awful low... also i have heard that the gaskets and such in the knuckle rebuild kit included with the tg kit are total crap
Old Mar 24, 2010 | 08:34 PM
waskillywabbit's Avatar
Questions:
I use TG kits on my trucks and they are the most complete for the money. Great kit is only as good as the installer.
I have 2 pickups and used 4" springs front and rear and can run 35s easy and 39.5s with firewall tubbing and trimming. 33s will look retarded.
Square driveshafts are a poor choice IMO when doing it right is not that expensive especially for a dd.
No need for anything over 4" springs unless you want to run huge tires.
Old Mar 24, 2010 | 09:17 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
The spring hangers alone will lift it 2-3".
So 4" springs = 7" of lift.
Old Mar 26, 2010 | 09:51 AM
i have also seen severl guys do knuckle ball gussets. how do you do this??? do they come in any kits?? also what should i do about a front driveshaft
Old Mar 26, 2010 | 09:53 AM
also, so... 4'' springs would be a bad idea if im still running 33's for now????
Flying91
45
Apr 11, 2024 04:39 PM
Shagool22
Aug 14, 2015 12:24 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
