problem with ADD
problem with ADD
I just bought a 1991 toyota because it has a 22 re and a five speed the down fall is the auto locking hubs are not locking in i suspect a bad switch the problem. but i don't know where the swich is located. is it on the t-case or on the shift lever?
any help is apreed
any help is apreed
This will help you see what is going on, not necessarily your solution:
http://www.4x4wire.com/toyota/tech/add/
Auto hubs and ADD are NOT the same thing.
EDIT" nvm
Thanks wabbit.
I had a problem with my ADD system, it was no longer getting vacuum to keep the shift fork locked, which wouldn't allow the front wheels to put the power to the ground.
I ended up bypassing the VSV's and ran a vacuum line directly from the ADD shift tube to the engine, this kept constant vacuum on my shift fork.
Before that i added manual locking hubs so i could unlock them and not have the cv's spin.
If you are going to do this you will need manual locking hubs.
Thanks wabbit.
Auto hubs were 84-89 only I believe, so he has ADD.
Some more info:
http://www.4x4wire.com/toyota/tech/autohub/
Some more info:
Werent auto locking hubs phased out/replaced by ADD in like '87..'88 or so?
so it has to be ADD
EDIT: Wabbit said it before i did
so it has to be ADD
in my eyes the cure would come in the form of a solid axle swap. but untill then i want to see if i can make what i have work. also my 4 wheel drive light does not come on. any idea where the swich is ?
jasonty
41
Dec 23, 2018 01:00 PM
