Sponsored by: CARiD
oil in radiator
Old Dec 4, 2006 | 06:55 AM
daveo's Avatar
oil in radiator
hi i am a newbie. i have a 95 4runner sr5 4wd a/t. i have oil in my radiator. i read some threads and i think it is a head gasket. i checked with toyota and my vin is not on the recall list so i am s.o.l. i do not however have water in my oil or tranny fluid. could it possibly be something else (hopefull but doubtful).. also if i drain the oily rad. fluid and put new rad. fluid in will it then get into the engine? any help of ideas would be great. thanks.
Old Dec 4, 2006 | 07:01 AM
SteelHound's Avatar
Does the Engine oil look milky?
Old Dec 4, 2006 | 07:03 AM
daveo's Avatar
no it always looks normal.
Old Dec 4, 2006 | 07:05 AM
kmcc78240's Avatar
More then likely yes HG blew. The coolant can go into oil or oil can go into the coolant. Mine blew at 154K, pin hole leak into one of the cylinders. Have you over heated?
Old Dec 4, 2006 | 07:08 AM
daveo's Avatar
i would never know the temp guage never goes above the half way point but sometimes the engine does hint that it is overheating ie valve chatter at 55 or 60mph and that hot hot engine smell when i get out of the truck. also my oil pressure guage has never gotten above the halfway point.
Old Dec 4, 2006 | 07:12 AM
daveo's Avatar
i think it is the head gasket. i think i have always known it but been in denial. i have a mechanic at the stealership that has been reliable so far and does side work. it is just getting the miney together to do it
Old Dec 4, 2006 | 07:19 AM
daveo's Avatar
thanks for your replies. have a good day!
Old Dec 4, 2006 | 07:22 AM
kmcc78240's Avatar
I understand the denial part, but you will feel better after it is done. good luck, lots of good info on here. Which I would have known about YT before my HG blew. Welcome by the way
Old Dec 4, 2006 | 07:26 AM
daveo's Avatar
thanks kmcc. yeah i know i will feel better once it is done, but it is just "getting to the getting it done" part that is painful but i am patient. thanks again!
Old Dec 4, 2006 | 07:29 AM
daveo's Avatar
oh one other question, when i buy the parts to fix the HG where should i get them from, NAPA or stealership?
Old Dec 4, 2006 | 08:15 AM
kmcc78240's Avatar
check out engine builder, at www.engnbldr.com, Very good stuff comes with everything.
wherei s alink to bumpin yotas thread
https://www.yotatech.com/forums/show...t=engnbldr.com
Old Dec 4, 2006 | 08:17 AM
daveo's Avatar
thanks i'll check it out!
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
the1998sr5
Jul 16, 2015 06:20 AM
horunner1x
Jul 10, 2015 06:33 AM
