Sponsored by: CARiD
new to toyotas
Old Nov 8, 2013 | 07:41 PM
  #81
RSR's Avatar
RSR
Originally Posted by theerroneouspenguin
I know. Sorry about the random ness. I like other peoples opinions then I make decisions based on that.
Anyway. My 4*4 light doesn't come on. :/
Was informed my front shocks are to long for a 2" lift. I only assume I have a lift. How can I be able to tell 100%?
Will also be getting new sway bar bushings and maybe a new sway bar. Mine is rusted.
Sorry for random. Any suggestions?
Do you have ADD hubs? If so, the front diff is vacuum controlled so a vacuum leak or failed control valve could allow your front diff to not lock in... (Pretty sure the electrical control in the front diff is what turns your 4wd light on).
Good news is that this is a low cost mod: http://www.4x4wire.com/toyota/tech/add/
Bad news is that the manual hubs (which eliminate front drivetrain drag and improve mpgs and reduce wear and tear to front axles and are essential if a daily driver and going w/ the ADD delete) can be a $100 to $150...
Old Nov 8, 2013 | 07:47 PM
  #82
RSR's Avatar
RSR
The 22re bulletproof ness is the main reason. I could always build the 22 for more power. At least enough to get in the hills Lol.
I hill around in rolinsville if anyone knows where that is. Its by Nederland.
22re bulletproofness is more myth than fact. 22r was more reliable.
The modern 4 cylinders only almost put out the same power of the 3vze. If you want power/performance equal to what you have now, the 3.0/3.4 is your best bet. With the 22r/re you're sacrificing power for a less congested engine bay, no plenum blocking access to half your engine, one head, and more aftermarket parts/support -- a big reason for that aftermarket though is unhappiness with power generated by the engine in stock form...
  #83
theerroneouspenguin's Avatar
I have no idea. I just read the page. Would be interested in doing it.
Old Nov 8, 2013 | 07:49 PM
  #84
RSR's Avatar
RSR
I'd recommend Bilstein or Old Man Emu shocks. Bilstein being more rigid, OME allowing more flex. Generally speaking, if primarily road, Bilstein. If primarily offroad, OME. Definitely look at OME's steering stabilizer however. That's a great product onroad or off.
Old Nov 8, 2013 | 07:53 PM
  #85
Im sitting in my truck smoking a cigerette. How can I tell if I have ADD?
Old Nov 8, 2013 | 07:54 PM
  #86
Makes total sense. The 3.0 hasent been bad. Not fast but fits my life just fine.
Old Nov 8, 2013 | 08:13 PM
  #87
RSR's Avatar
RSR
Vacuum canister under passenger wheel well towards front? And inside of engine bay looks like this:
-Two vacuum controllers w/ vacuum lines (where dark caps are under lower line out of the vacuum canister).
Essentially, if you have 4wd and don't have the manual hubs, you therefore have the ADD system installed w/ standard, always locked hubs.
EDIT: Good read on hubs: http://4x4abc.com/4WD101/hubs.html
Old Nov 8, 2013 | 08:14 PM
  #88
http://www.off-road.com/trucks-4x4/f...tem-19259.html
He talks about the types of hubs. I have the standard hubs that are always locked.
Old Nov 8, 2013 | 08:15 PM
  #89
And its best to keep it locked? Like that one link you posted? I should just do away with it?
Old Nov 9, 2013 | 09:05 AM
  #90
Got the gate to drop.
Had to move a pin to move it to unlock. Took a few minutes to get the paneling off,window down a bit and it dropped. Knocked the window off track a little but got it back on and up.
Works.
Have the metal panel off and just the carpet back on. At least we have a gate now.
Is there a way to just delete the lock all together? Cause with my key I can't unlock any doors anyway so why have the gate locked?
Old Nov 9, 2013 | 09:12 AM
  #91
And my rad is cracked.
Old Nov 9, 2013 | 01:35 PM
  #92
Do I have to use the manual hubs? I'm already pulling crap milage. Lol
Old Nov 9, 2013 | 03:31 PM
  #93
thafluffinato's Avatar
Nice rig man! I've had my yota for 2 years now and I love it.
I plan on doing the ADD delete as well, Aisin sells some great Manuel hubs that I hear are better then the warn ons! Anything to get better MPG's! Sub. To thread!
Old Nov 9, 2013 | 03:39 PM
  #94
Thanks for the heads up. I'm looking the hubs up now but I see them in different sizes. I've seen a 26 spline and a 30 spline. How do I know what I need?
http://www.ebay.com/sch/i.html?_kw=toyota+hubs+aisin
Old Nov 9, 2013 | 04:18 PM
  #95
Thanks for the heads up. I'm looking the hubs up now but I see them in different sizes. I've seen a 26 spline and a 30 spline. How do I know what I need? http://www.ebay.com/sch/i.html?_kw=toyota+hubs+aisin
Normally IFS are 26 spline and SFA are 30, I believe. Don't quote me on that but I did some research and that what I found.
Old Nov 9, 2013 | 04:49 PM
  #96
Makes sense. Thanks.
Old Nov 9, 2013 | 04:59 PM
  #97
No problem buddy! Be sure to post pics and keep us updated on the build!
Old Nov 9, 2013 | 05:12 PM
  #98
Its gonna be slow. I'm gonna have to put a lot of cash into it and I have no job. Lol
Time to sell some stuff
Old Nov 9, 2013 | 06:33 PM
  #99
Are there any standard bolts or anything on the yotas? I'm used to metric and have a crap ton of standard stuff I don't need.
Anything I should keep?
Old Nov 9, 2013 | 06:40 PM
  #100
Are there any standard bolts or anything on the yotas? I'm used to metric and have a crap ton of standard stuff I don't need. Anything I should keep?
Pretty much no, metic is the only thing I ever use, keep it off you ever plan on working on anything domestic. I work at a Hyundai dealership and never use standard, on any of the imports that is.
