Sponsored by: CARiD
New Here - Exhaust ?
Old Dec 8, 2008 | 05:06 PM
Fixxxer247's Avatar
Hello all!
My truck is a '94 Toyota 4x4 2.4L Stock! I need a new exhaust pipe (the one that connects to the exhaust manifold and goes down to the converter). What is a good/cheap stock replacement one to get. The cheapest I could find is $89.
Thanks!
Old Dec 8, 2008 | 05:14 PM
toyota4x4907's Avatar
I wouldn't skimp out too much. I'd say get the $89 one. What happened that you need it? I had to replace mine last year because it developed a crack in the bend part...which in time grew..and finally it split in two. I think it had something to do with the cold here and the hot exhaust and rust. I got mine from CarQuest for $110, but its a pretty nice one. And they're usually called down pipes.
Oh yeah! Welcome to YotaTech
Old Dec 8, 2008 | 05:17 PM
littlecommando's Avatar
Welcome to yotatech!
Old Dec 8, 2008 | 05:28 PM
Fixxxer247's Avatar
The reason is it seperated at the seam (about 4"-5" from the the manifold connection). I would just get out the welder and run a bead on it but, I only have a Flux Core welder, and it probably won't do very well on thin exhaust pipe.
Old Dec 8, 2008 | 05:40 PM
fireman1559's Avatar
if you used gas and you were a good welder and you didnt have the heat very hot you could weld it or TIG weld it
Old Dec 8, 2008 | 05:49 PM
Fixxxer247's Avatar
Oh trust me I would weld it if i had gas or a TIG welder
Old Dec 8, 2008 | 05:53 PM
if you were down here id weld it for you ive got a TIG and a MIG welder
Old Dec 8, 2008 | 05:54 PM
You could get a shop to weld it. It would probably be cheaper than buying a new one.
Old Dec 9, 2008 | 08:48 AM
Fixxxer247's Avatar
Will this one work? CLICK HERE!
Thanks!
Steven.m.paulk
Jun 7, 2020 10:45 AM
the_supernerd
Oct 1, 2015 09:20 PM
voiddweller
Sep 28, 2015 11:21 PM
Keithstoyota
Sep 27, 2015 07:29 AM
