Front brake job
Front brake job
I changed the calipers and pads on this truck , 8/15/2016 and I just had to do it again, the outside pad was worn to the metal on the pass side, down to bout 3/8 inch on the outside pad on the driver side, the inside pads on each side had lots of meat, I also changed the flexible brake hoses this time. Now after bleeding the system 3-4 times the brakes are still spongy. Any input will be appreciated.
I have not had success downloading pics on this forum, but I did take them
Thanks for the reply olds, my thought as well, yes put on new calipers, pads and flex hoses both sides, bled the whole system about 3-4 times, still the brakes are low, as mentioned, I relaced the pads and calipers, but not the flex hoses, about 2 years ago, I don't put many miles on this rig, so we will see how they wear this time
When you say "I changed the calipers and pads" do you mean you took some off of another truck or that you bought new? Looking at your pads I would guess the latter, because it looks like you have some pistons hung up and not working (on the pad that isn't worn) or pistons not returning (on the worn out pad). either that or you slapped them on rotors that were already ground metal to metal on that side and ate the pad because of the rough surface. The pads are the symptom not the cause, pictures of the rotors and calipers would be far more helpful since it doesn't take much imagination to understand what you meant in your original post about pad wear.
thanks for all the help
This may have all started with a bad caliper (stuck pistons on the inside). All you really need now is new rotors and new pads (again). The only right way to do a brake job (safety is on the line here) is to put new flat pads on a flat rotor surface and you need to be sure there is enough rotor thickness left for proper cooling. if you put new pads on a grooved or ground up rotor you will not get full contact until the pad wears into the shape of the rotor surface and you will never get proper braking out of it. Problems can include: pulling to one side under braking, poor stopping power, poor pedal feel, squealing, grabbing, short pad life, brake fade etc.
Thanks ak, sounds like you know a lot about brakes, maybe that's why I can't get the brakes adjusted to where I want them. Right now I need to replace the passenger side steel brake lines on my 91( that's another thread)
thanks for your help Ak
FleshThorn
Apr 7, 2011 07:31 AM
spage
Jul 31, 2009 09:56 AM
Uisge Beathe
14
Jul 26, 2009 03:02 PM
