81 toyota front drive shaft. Need help
Does any know what other front drive shafts i can use on an 81 toyota? I need a new one and i cant find a one anywhere! Snows here and 4wheel drive isnt working.... Thanks in advance
What's wrong with yours? Or do you not have one? If you still do then all you have to do is take it to any shop that works on drive shafts or u joints and get it fixed if you cannot find a replacement. That's what I did on my 82. It had a crap repair job done on it and I also could not find a replacement so they just fixed the one I had and they balanced it too.
since you are in PDX: Give Brian a call at http://www.drivelinetech.com/home.php
Light truck parts on Foster usually has a stack of front drive shafts $75:
http://www.lighttruckpart.com/
just be aware that later model trucks 86+ the drive shaft will be about 4" long and will require that you clearance the CV.
or check the stickies and you might have found this:
Toyota Truck Dismantlers: body parts/axles etc
The Toy Man (newberg, OR) http://www.thetoyotaman.com/
MazToy (troutdale, OR)http://maztoy.com/
Davez Off Road: http://www.davezoffroadperformance.com/
Yotayard (colorado) http://www.yotayard.com/home.htm
Jim's Got Parts (Denver, CO) http://jimsgotparts.com/
California Mini Trucks (Cali) http://www.calminitruck.com/
NIX99 (washington state) http://nix99.com/
Rancho Toyota Truck Dismantler (Cali) http://www.ranchotoyotatruckparts.com/
toy truckc (CA) http://www.toytruckscalifornia.com/
Toy Connection (CA) http://www.toyconnection4x4.com/home.html
All Toyota Truck and SUV (CA) http://www.alltoyotatrucksuvparts.com/
ToyoKings (FLA) http://www.toyokingsusedparts.com/
Yotatech Classifields :https://www.yotatech.com/forums/f91/
TTORA Classifieds: http://ttora.com/forum/forumdisplay.php?f=3
Pirate classifieds: http://pirate4x4.com/forum/forumdisplay.php?f=4
Parts Locators: http://www.autopartslocator.com/
http://www.seekautoparts.com/
DeNaples (Dunmore, PA) http://www.denaples.com/
New sheetmetal parts-Rust Repair Panels: http://www.alfaparts.net/toyotapu.htm
yes, i understand you are talking about the front and nope unless it is lifted like 6+ inches you cant fit a newer one under there at least i would say not. you could bolt one up and see if it would, but i would not hold my breath. before i did my tranny swap and duals i tried a driveline out of an 85 and it was too long. i have a 3" lift.
goodluck
goodluck
6th Gear
19
Dec 10, 2019 07:31 AM
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
