Sponsored by: CARiD
81 toyota front drive shaft. Need help
Old Nov 22, 2010 | 09:00 PM
81YOTABOY's Avatar
Does any know what other front drive shafts i can use on an 81 toyota? I need a new one and i cant find a one anywhere! Snows here and 4wheel drive isnt working.... Thanks in advance
Old Nov 24, 2010 | 09:53 PM
maistroyoda's Avatar
What's wrong with yours? Or do you not have one? If you still do then all you have to do is take it to any shop that works on drive shafts or u joints and get it fixed if you cannot find a replacement. That's what I did on my 82. It had a crap repair job done on it and I also could not find a replacement so they just fixed the one I had and they balanced it too.
Old Nov 24, 2010 | 11:44 PM
81YOTABOY's Avatar
Ya mines crap, i brought it to a shop called 6 states hopefully they can fix it so i can do some wheelin! Life sucks with 2wd.
Thanks for the reply!
Old Nov 25, 2010 | 12:27 AM
wyoming9's Avatar
Red face
If it is beyond repair Having a new one made is not really that expensive.
I rebuild these trucks so I have needed to have several made with grease fittings on the ujoints.
Old Nov 25, 2010 | 04:03 AM
dropzone's Avatar
Fossilized
since you are in PDX: Give Brian a call at http://www.drivelinetech.com/home.php
Light truck parts on Foster usually has a stack of front drive shafts $75:
http://www.lighttruckpart.com/
just be aware that later model trucks 86+ the drive shaft will be about 4" long and will require that you clearance the CV.
or check the stickies and you might have found this:
Toyota Truck Dismantlers: body parts/axles etc
The Toy Man (newberg, OR) http://www.thetoyotaman.com/
MazToy (troutdale, OR)http://maztoy.com/
Davez Off Road: http://www.davezoffroadperformance.com/
Yotayard (colorado) http://www.yotayard.com/home.htm
Jim's Got Parts (Denver, CO) http://jimsgotparts.com/
California Mini Trucks (Cali) http://www.calminitruck.com/
NIX99 (washington state) http://nix99.com/
Rancho Toyota Truck Dismantler (Cali) http://www.ranchotoyotatruckparts.com/
toy truckc (CA) http://www.toytruckscalifornia.com/
Toy Connection (CA) http://www.toyconnection4x4.com/home.html
All Toyota Truck and SUV (CA) http://www.alltoyotatrucksuvparts.com/
ToyoKings (FLA) http://www.toyokingsusedparts.com/
Yotatech Classifields :https://www.yotatech.com/forums/f91/
TTORA Classifieds: http://ttora.com/forum/forumdisplay.php?f=3
Pirate classifieds: http://pirate4x4.com/forum/forumdisplay.php?f=4
Parts Locators: http://www.autopartslocator.com/
http://www.seekautoparts.com/
DeNaples (Dunmore, PA) http://www.denaples.com/
New sheetmetal parts-Rust Repair Panels
: http://www.alfaparts.net/toyotapu.htm
Old Nov 25, 2010 | 10:59 AM
81YOTABOY's Avatar
Will the 86 and newer just bolt right up?
Old Nov 25, 2010 | 11:05 AM
just call me smithy's Avatar
im not sure if the drive shafts are interchangeable but if they are im in beverton and i have two spare drive lines for a 91 4runner ifs on my roof-rack, i dont mind helping a fellow yota out. let me know
Old Nov 25, 2010 | 11:12 AM
INFINITY's Avatar
80 to 83 will only fit assuming u r using a tranny from 80-83. 84+ have longer trannys and therefor the driveline from these later ones will not fit, they will be too long.
Old Nov 25, 2010 | 01:27 PM
81YOTABOY's Avatar
Wouldnt a longer one be better since my truck is lifted? Im talking about the "front drive line"
Old Nov 25, 2010 | 04:59 PM
INFINITY's Avatar
yes, i understand you are talking about the front and nope unless it is lifted like 6+ inches you cant fit a newer one under there at least i would say not. you could bolt one up and see if it would, but i would not hold my breath. before i did my tranny swap and duals i tried a driveline out of an 85 and it was too long. i have a 3" lift.
goodluck
Old Nov 26, 2010 | 02:41 AM
81YOTABOY's Avatar
Ok thanks a lot! That saved me money and time
Old Nov 27, 2010 | 09:57 AM
81YOTABOY's Avatar
Finally found 1 out of an 83 at a1 light trucks and vans on columbia blvd. Yay
6th Gear
19
Dec 10, 2019 07:31 AM
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
