Rattling sound
Old Dec 7, 2012 | 11:47 AM
hogv8's Avatar
Rattling sound
I'm new to the forum . I own a used 2004 Toyota 4 runner V6 and it has a dull rattling sound when letting off the gas at 40 to 60 MPH . Lower or highway speeds there is no sound . It sounds like a cable or similar sound coming from somewhere under the vehicle . Another way of describing the dull sound is marbles rolling around inside of a plastic jar . I looked everything over underweight and secured everything that could possibly rattle and the sound is still there . Universals seem good , I just can't figure out where this sound is coming from . Any ideas
Thanks HOGV8
Old Dec 8, 2012 | 08:24 AM
hogv8's Avatar
Can anyone help me with this rattling sound problem ?
Thanks HOGV8
Old Dec 8, 2012 | 08:46 AM
Fink's Avatar
The original section you posted this in was a staging area for Tech Write-Ups - doubt many people noticed it. It has been moved to the 03+ 4Runner/GX470, & 05+ Tacomas section.
As for your rattling sound, did you check to see if there are rocks or debris in the cat converter heat shield?
Had that happen to me on every rig I've owned.
Fink
Old Dec 8, 2012 | 09:15 AM
hogv8's Avatar
Thanks Fink , I'll have to check that out .
Jack
Hogv8
Old Dec 8, 2012 | 09:19 AM
Fink's Avatar
Jack
Hogv8
Easiest way to check is take a rubber mallet out with you and start banging on stuff. I found at least five or six rattles/squeaks this way on my old '85.
Good luck and let us know what you find out!
Fink
Old Dec 8, 2012 | 09:24 AM
hogv8's Avatar
I've already done most of that and fixed a few things that potently could cause a rattle but the noise is still there . Even thought there are no indications I wonder if it could be drive train related . If there is something causing this rattle I sure can't figure out what it is .
Jack
HOGV8
Old Dec 12, 2012 | 06:40 AM
hogv8's Avatar
I read a lot of posts on mysterious rattling coming from under carriage on a 2004 Toyota 4 runner and I'm starting to believe my rattle is coming from my exhaust . I can see a definite hole in the resonator near the rear of the exhaust and possibly a small hole in my muffler .
Some guys mentioned possibly the noise is coming from inside of the cat converter also ???
Thanks , Jack
HOGV8
Old Dec 17, 2012 | 11:31 AM
hogv8's Avatar
Well , after eliminating everything else I could find that could be causing my rattle I decided to remove the spare tire from underneath the rear of the 4 Runner . Of course it was rusted and I had to cut the cable to get it down . No good underneath anyway in my neck of the woods . Anyway after I got the spare down and removed I took the 4 Runner out for a test drive . Wallaa , no more rattle .
Thanks for your help , Jack HOGV8
zytra
Jan 24, 2019 03:16 PM
Corvoid
Dec 11, 2015 11:21 AM
irv
Sep 29, 2015 01:04 PM
voiddweller
Sep 28, 2015 11:21 PM
toyotasaurus
Sep 24, 2015 03:30 PM
