4th gen trans flush
Old Sep 25, 2007 | 05:21 PM
hamiltonj2w1's Avatar
4th gen trans flush
I have read all of the posts about trans flushes and just drain and fills. The dealer tells me to only use the Toyota brand trans fluid aka T4. My reputable local trans shop said the stuff they use is regular ATF but they put an additive in it to make it the same as the manufacturer. I have read people claiming that after they had it flushed they had problems with slipping and shifting. I just want to make sure I am not making the wrong choice by going to the local trans shop and not the dealer who has screwed me over in the past. Thanks for any and all input.
2004 4runner 4.0 V6 SR5
49,000 miles never towed anything some mild 4wheeling
265/70/17 Nitto Terra Grapplers
Old Sep 25, 2007 | 05:35 PM
Ringmaster's Avatar
Just go purchase a case of Toyota ATF at an oil distributor. And drop it off to your freind.
Old Sep 25, 2007 | 06:02 PM
CTRJ's Avatar
00279-000T4, see if you can buy that part number for a good price somewhere. If not, let me know, maybe I can help you out.
Old Sep 27, 2007 | 11:33 AM
Mikestang's Avatar
To do a complete flush on the sealed trannies you need the Toyota computer to open all the valves and stuff inside, otherwise you're just getting what's in the pan. Why do you want to change the fluid with only 49k miles, no towing, and no hard off-roading? You're probably good past 100k driving like that.
Old Sep 27, 2007 | 12:29 PM
Knuckles's Avatar
Toyota's responses to spark plug and transmission fluid questions
Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
We appreciate the opportunity to address your inquiry.
The standard spark plugs in the 2004 4Runner V8 are 120K Iridium plugs. They will not need replacement until 120 thousand miles.
In the effort to minimize service required, the new transmissions do not require a fluid change, unless necessary with very heavy load conditions. There is a temperature sensor in the transmission that would alert the driver, if the load was super heating the transmission.
I would also use ONLY Toyota Transmission fluid, it is a special transmission fluid called World Standard (WS)
Old Oct 1, 2007 | 08:46 AM
Duc Hunter's Avatar
In the Audi world many people tried to use non Audi tranny oil, and most had to get new trannys soon after. 2 options. Every service suck the oil out of the pan and replace it. Does this get all the old oil, no. Over time though you will be changing out all the oil. Option 2, have the dealer do it right, open the valves etc. I might want to watch them to see just how much oil they get out though. I seem to remember that the 2003's had an AT dip stick for the 5 speed, and in 04 they went sealed.
Me, I just tell the dealer to do the "heavy use service" which is a complete flush & oil change, like those who tow would need.
Old Oct 12, 2007 | 05:13 PM
wutastic's Avatar
only use toyota fluid. dont forget, ur powertrain warranty is longer than the 3 year 36k mile base warranty. i had to deny a warranty claim to a customer because when the fluid tests came back from toyota, it wasnt the right fluid. felt bad that i had to tell him that its goin to cost him 4grand for a trans and 15 hours of labor to install it. just something to keep in the back of your mind. spend the extra money, get it done at the dealership.
check and see if you even have a trans dipstick. if not, you dont touch it until it hits 100k.
Old Oct 22, 2007 | 08:55 PM
ARB1977's Avatar
With any sealed unit take it to the dealer...at least my 02 has a dipstick.
krimsonone
Sep 13, 2024 09:33 AM
crammit442
7
Nov 29, 2017 12:30 PM
nick9455649
Sep 11, 2015 05:10 PM
Pedalpwr27
Aug 13, 2015 06:37 AM
Jnkml
Jul 6, 2015 01:20 PM
