wont start
wont start
Ok ive worked day and night for 3days and cant get this truck to start I have brand new spark plugs, my ditributor is gettin fire, Im gettin gas to the fuel rod or (fuel bar), all it does is turn over. It doesnt sound like its goin to fire at all. what else could it be. The injector are only 1500miles old. it an 94
i have the same issue but my truck sputtered and then died one day..it wont start on starting fluid..new plugs wires cap rotor....ignitor and coil tested fine.. if i remember correct its been about a month..
@baseballchamp157-
I know you've probably posted before on this, but you started a new thread so...
what do you mean by you've worked on it?
why were you working on it?
what have you done to it?
well I know that its gettin fuel because the hose from the fuel rod that goes to the efi shoots out fuel when you try to start the motor. My cylinders are gettin fuel though. I know this because my spark plugs are brand new and i stuck them in, tried to tart it and took them out and that were as dry as hard poop. plus you couldnt smell gas on them either. But my injector are almost brand new and were workin before my HG blew
but, if you meant "aren't getting fuel", I'd start looking at the injector wiring before I go anywhere else.
I meant the cylinders arent gettin fuel. yes i have compression. all I did with the head it took it to a machine hop and have them pressure test it and shave it. nothing was doen to the valves. I mean it does sound to me like the injector but theyre only 1500miles old. so they cant be bad can they?
a multimeter can help you trace down wiring issues.
also, most autoparts stores sell injector test lights which plug into the injector connector and 'blink'.
I just went through this same problem on my 86 4Runner 22RE, i had spark and fuel but no start, it turned out to be a bad solenoid resistor, replaced it and she started right up. power comes from the hot side of the ignition switch to the solenoid resistor, wich i guess lowers the voltage to the plus side of the injectors and then sends power through the injectors and to the computer. look in a factory service manual, it will explain it alot better than i can.
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
