Wiring harness routing 87 re, lost all power after motor swap
Old Mar 29, 2020 | 01:09 PM
Dk29's Avatar
New to this forum thing, done many engine rebuilds and modifications. I installed the harness on the new motor I built but think I routed it wrong. The starter wire seemed a little short along with some other plugs, ( its egr deleted) so I know not all of them are used, pics of the routing would be helpful. Also as I went to fire it, it had power to the ignition, it clicked once and no power to anything? Thanks in advance for any insight.
Old Mar 30, 2020 | 07:12 AM
13Swords's Avatar
5 Year Member
Best to go find & get a service manual that has a wiring diagram to help you put it back together correctly. Meanwhile here is what I have:
http://www.offroadforum.cz/toyota/aa..._DIAGRAMS.html
Scroll down to find the '87 diagrams, there are 4 of them.
Old Mar 30, 2020 | 12:58 PM
RAD4Runner's Avatar
Start with this, and report back. This is from 198 4Runner. Wire color code should be same as 1987's
Old Jul 20, 2020 | 07:38 AM
Dk29's Avatar
Sorry for the long delay. I ended up finding a bad relay under the kick panel. I replaced everything wiring lies from fuel pump forward and all the fuel pressure regulators and fuel dampers come to the conclusion that it was a $6 relay after changing the main fuse and every single fuse in the truck. I tested the relay and it seemed to be clicking but there wasn't enough juice going through it.
Old Jul 20, 2020 | 07:39 AM
Dk29's Avatar
Needless to say everything under the hood wiring wise and fuel wise is brand new
Old Jul 21, 2020 | 05:52 AM
13Swords's Avatar
5 Year Member
Sometimes that happens because the contacts on the relay get pitted or corroded, due to arcing. It's just the nature of the beast. Hard to see it since the contacts are sealed inside a case, so don't feel too bad, it's gets the best of us.
At least now you know everything to do with that circuit is top notch.
Old Jul 21, 2020 | 01:54 PM
2ToyGuy's Avatar
Thankfully, Westinghouse (The Circle-Bar_W Check their emblem ) put relays with clear cases in the high-failure areas of the radar I used to work on many years ago. Made finding the ones, like your's, with bad, arced contacts, a LOT easier.
One of the few things they did right with that system...
Pat☺
Old Jul 22, 2020 | 08:15 AM
13Swords's Avatar
5 Year Member
I used to work for Westinghouse, assembling the manuals for those radar systems. Small world.
Old Jul 22, 2020 | 09:58 AM
2ToyGuy's Avatar
Apparently it is! Well whadda ya know!
Aero-1A, Awg-10 A/B/C (I aint scared of no HAWG! ), I forget the designation of the one used in the Aerostat program.
Any of them ring a bell? F-4N/J/S radar systems. I got downright good on them
OK, done hijacking the thread.Sorry about that...
Have fun, all!
Pat☺
Old Jul 24, 2020 | 11:22 AM
Dk29's Avatar
Have fun, all!
Pat☺
it's all good man, hell I'm always interested in learning new things
rAvery
21
Aug 28, 2014 03:14 AM
beerbottle81
Nov 1, 2007 09:39 PM
dc'stoy
Mar 9, 2007 04:04 PM
LevZeppelin
7
Oct 12, 2004 11:36 PM
