Wiper Upgrades?
Old Sep 18, 2010 | 11:05 AM
vsi1600's Avatar
Wiper Upgrades?
I have a '90 Pickup DLX and it only has two wiper settings, well three, OFF, low, and high. That's not enough!
Has anyone ever tried upgrading to a newer switch with more settings? Or done something custom?
Old Sep 18, 2010 | 11:46 AM
mightymouse's Avatar
that's a good idea. I've never thought of that but it would be nice to have some more settings on my truck's wiper function. Mine on the other hand has three settings that each can be tuned from slower to faster with the second switch. So basically i have slow with three extra settings, medium with three extra settings, and fast with three extra settings. So it's basically a dual switch with variables for each speed. Scribed to see what others think. But to be honest i'm pretty satisfied with the function the way it is guess that's why i never thought to change it. Maybe yours is different.
Old Sep 18, 2010 | 11:49 AM
camo31_10.50's Avatar
how about putting a new motor in the runs faster? a long with a new switch
Use RAIN-X if yours don't work good enough..it's what i use in my '86 and my '96 dodge..and i hardly ever use my wipers.
i even put it on the side windows and the back window of my '86 lol
Old Sep 18, 2010 | 11:51 AM
iamsuperbleeder's Avatar
I hear the delay wipers setup out of an SR5 is a direct swap. Supposedly all that has to be swapped is the wiper switch in the steering column
SO I'VE HEARD
I've never personally tried it, but always wanted to
Old Sep 18, 2010 | 12:27 PM
myyota's Avatar
It can be done, i converted a base model 84 4Runner over to intermitent wipers and it was easy to do. You will need to swap out the wiper switch and add the relay box that`s required for the intermitent wipers to work.
Old Sep 18, 2010 | 03:12 PM
thralldad's Avatar
Write up?
Old Sep 18, 2010 | 03:27 PM
MaK92-4RnR's Avatar
high performance wipers... what is the world coming to?
Old Sep 18, 2010 | 04:05 PM
peow130's Avatar
i bought some decent wipers once.
then i hit a mudhole, got a ton of dirt on them, then the mud froze overnight, and the stupid things dulled like crazy
Old Sep 18, 2010 | 04:31 PM
myyota's Avatar
Originally Posted by thralldad
Write up?
To add intermittent wipers you need the relay box (make sure to get the small wiring harness that goes to the relay box) and the wiper switch, you swap out the standard wiper switch for the delay switch, and then you go under the dash up next to the heater blower housing and there should be a plug with a jumper loop plugged in to it, unplug the jumper and plug the relay box into that plug and that`s it your done. you now have intermittent wipers.
Old Sep 18, 2010 | 06:00 PM
Zelephant's Avatar
Hmmmm, I have a 89 DLX and my truck has an intermittent setting. Were some sold like that, or were they swapped in somewhere along the line?
Old Sep 18, 2010 | 07:19 PM
peow130's Avatar
Mine has intermittent, and it's also DLX.
Probably an option the PO wanted
Old Sep 18, 2010 | 09:28 PM
vsi1600's Avatar
Very good info. I saw that jumper when I changed my heater core.
Thanks for all the other replies too.. some good info going now. Dunno why some DLX's didn't come with it, but it's definitely needed in Alaska... Two speeds is not enough!!
Old Sep 18, 2010 | 09:32 PM
mine has it...but i usually either run them on high...or just flip the switch to wipe it once.
like i said...RAIN-X WORKS WONDERS!!!!!
i use the rain-x windshield wash too...like $2 for a big jug of it
kawazx636
Oct 6, 2021 03:03 PM
SpookyMulder
Nov 4, 2015 11:56 AM
89YodaRunner
Sep 30, 2015 02:18 PM
PNW94Runner
Sep 29, 2015 02:55 PM
4runnerFireman
Sep 29, 2015 06:24 AM
