wiper help
ok I searched high and low ad cannot find anything.. heres my problem I bought my 89 Toyota pickup 2 years ago and I only replaced the wipes once but I had to use the wiper refill replacements that are cut to length im looking for the j hook wiper arms so I can run any wiper with a j hook but im not having any luck finding anything I heard about the adapter but I can find it anywhere any help
Not knowing where you live but your local autoparts should be able to help.
You can ask on here if some one has a set of the newer style wiper arms j hook for sale or go yarding your self.
Me I still use the old style arms that the wiper blades attach with the screws.
I have no problems getting blades.
im in Marquette Michigan I have napa, advance auto, auto value, carquest, orieley
mostly go to advanced auto..
well I tried that adapter that comes with the wipers and they don't fit
I found this side saddle adapter on summit racing would these work http://www.summitracing.com/parts/anc-48-08
sounds like the OP has been buying replacement rubber to use in his old "frames"
not entire replacement blade assemblies...
J hook is/was the standard wiper arm for toyota trucks anyway... it is possible that a previous owner of your truck put different arms on it.
as for a junk yard source... you will most likely come across 90+ 2gen runners go ahead and grab any of them they are the same as are used on the trucks.
95+ Tacomas (the smaller ones not the current type) also use the same arms.
PNW94Runner
Sep 29, 2015 02:55 PM
