wiper help
Old Apr 20, 2013 | 07:14 PM
wolf28's Avatar
Question wiper help
ok I searched high and low ad cannot find anything.. heres my problem I bought my 89 Toyota pickup 2 years ago and I only replaced the wipes once but I had to use the wiper refill replacements that are cut to length im looking for the j hook wiper arms so I can run any wiper with a j hook but im not having any luck finding anything I heard about the adapter but I can find it anywhere any help
Old Apr 21, 2013 | 12:06 AM
wyoming9's Avatar
Red face
Not knowing where you live but your local autoparts should be able to help.
You can ask on here if some one has a set of the newer style wiper arms j hook for sale or go yarding your self.
Me I still use the old style arms that the wiper blades attach with the screws.
I have no problems getting blades.
Old Apr 21, 2013 | 05:21 AM
wolf28's Avatar
any part numbers
what are the new style wiper arms
Old Apr 21, 2013 | 06:28 AM
JohnnyCanuck's Avatar
Most replacement blades come with the plastic piece so you can either use the j hook style or use the adapter to pop them onto the wiper arm pin
Old Apr 21, 2013 | 07:15 AM
wolf28's Avatar
I never seen the adapters when I buy the wipers
Old Apr 21, 2013 | 08:09 AM
I don't know, maybe because you're buying cut to length..? I know at Canadian Tire, the brands they carry has that adapter, and the have little packages that have just the adapters as well.
Old Apr 21, 2013 | 09:01 AM
Bullet22r's Avatar
when you get a chance to go to the salvage yard try to get wiper arms off bmw e30s fits on my 86 truck.
Old Apr 21, 2013 | 09:38 AM
wolf28's Avatar
Is it like a 3 spot clip and the flat wiper arm goes into it and looks like u can screw it to the arm
Old Apr 21, 2013 | 12:15 PM
wyoming9's Avatar
Red face
Be nice to know where you are and who you buy parts from.
Other wise part numbers don`t help much.
If your really stuck I could get you some.
Old Apr 21, 2013 | 01:21 PM
wolf28's Avatar
im in Marquette Michigan I have napa, advance auto, auto value, carquest, orieley
mostly go to advanced auto..
well I tried that adapter that comes with the wipers and they don't fit
I found this side saddle adapter on summit racing would these work http://www.summitracing.com/parts/anc-48-08
Old Apr 21, 2013 | 05:21 PM
wolf28's Avatar
to the top bump
Old Apr 21, 2013 | 05:48 PM
aviator's Avatar
Napa here in Canada sells those kind of wiper blades...
sounds like the OP has been buying replacement rubber to use in his old "frames"
not entire replacement blade assemblies...
Old Apr 21, 2013 | 06:03 PM
Toyota~Boy's Avatar
Go to eBay.com
Type this number in the search menu 151024077784
There's a set of wiper arms that have the J hook on them. Note that 84-95 are interchangeable.
Old Apr 21, 2013 | 06:16 PM
wolf28's Avatar
what years used the j hook I could go to the junk yard and try finding a set
Old Apr 21, 2013 | 06:23 PM
Toyota~Boy's Avatar
My 84 had them and both my 87 and 93 have them. Now I did have a 88 that didn't have them so I dunno exactly how that works
Old Apr 21, 2013 | 06:37 PM
wolf28's Avatar
I would think the newer years would have them
Old Apr 22, 2013 | 06:02 AM
aviator's Avatar
J hook is/was the standard wiper arm for toyota trucks anyway... it is possible that a previous owner of your truck put different arms on it.
as for a junk yard source... you will most likely come across 90+ 2gen runners go ahead and grab any of them they are the same as are used on the trucks.
95+ Tacomas (the smaller ones not the current type) also use the same arms.
Old Apr 22, 2013 | 08:47 AM
wolf28's Avatar
well I guess not I checked junk yard nothing there I guess im getting the ebay ones as long as these work
okamikai
Apr 30, 2018 10:19 PM
ghostmoney
Jan 28, 2018 11:42 AM
pickle6415
Dec 25, 2015 07:34 PM
PNW94Runner
Sep 29, 2015 02:55 PM
VT2LAB
Sep 10, 2015 09:36 AM
