Whining new alternator on 87 PU. 22R engine
Old Sep 5, 2022 | 08:52 AM
ahdofu's Avatar
Whining rebuilt alternator on 87 PU. 22R engine
Having replaced the alternator with a rebuild one from Carquest, I noticed the whining issue. There is only one belt and that belt drives both the fan and the alternator. Replaced the belt and that wasn't it. Ended up returning the alternator and bought another rebuilt one from Rock Auto (ACDelco). Same whining issue with this alternator as well. The belt has been properly tensioned. I can return this alternator and get another one or may be the issue lies with something else that I have not thought of. Reaching out to the Forum Community, do you buy new Toyota alternators or grab rebuilt ones and if the latter, what brand do you go with?
Thanks,
Matt
Old Sep 6, 2022 | 08:26 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I would only use Denso.
If you have a Denso alternator its pretty easy to replace bearings and brush holder. If you need the ic regulator than its better to just get a replacement reman.
Old Sep 6, 2022 | 04:30 PM
ahdofu's Avatar
Who do you buy these from?
Old Sep 6, 2022 | 05:03 PM
Jimkola's Avatar
YT Community Team
5 Year Member
Part number from Denso should be 210-0106. But please go to Denso Find My Part and check. Amazon has one of the better prices, and they usually don’t require a core return. Availability can be an issue at time though.
Old Sep 6, 2022 | 07:25 PM
Jimkola's Avatar
YT Community Team
5 Year Member
Did you ever try putting the old belt back on?
Old Sep 8, 2022 | 03:55 AM
ahdofu's Avatar
Thanks. I will check out Denso's. I have not put the old belt back on. The old and new belts are not the culprits.
Old Sep 8, 2022 | 07:04 PM
RAD4Runner's Avatar
Got my Denso, manufactured with pride in the U.S.A., not made in the Communist Bully, from LOCAL NAPA for $142 + tax. Best deal because I would not have to worry or pay for shipping the core.
I also like McGeorge Toyota. Got me better prices for the past couple of purchases compared to Toyota Part Deal. So to date, I compare total cost between that, Lakeland and TPD.
Reman by Denso in the U.S.A. $143 Plus tax from NAPA. Excludes core refund.
Already installed and equipped with a splash shield to keep it clean.
Old Sep 10, 2022 | 04:10 AM
TrafficTechII's Avatar
Thanks,
Matt
Is it all the time?
I would take the unit to a store that offers free testing to see it makes the whining noise there.
Are you sure its the alternator making the noise? Anything with a pulley can make a whining noise.
Old Sep 10, 2022 | 05:50 AM
snippits's Avatar
McGeorge Toyota is pretty dang good. They even went to the extreme, and found a Toyota brake line that fit perfectly on my 92 pickup. Can't remember what Toyota vehicle it fit, but it dang sure was not a truck part.
Old Sep 10, 2022 | 06:47 AM
ahdofu's Avatar
Originally Posted by TrafficTechII
Is it all the time?
The noise is certainly more noticeable at higher engine RPM. It could be the pulley on the alternator, the alternator fan, brushes or perhaps the bearings. The noise wasn't there with the old alternator. Both rebuilt alternators are showing similar noise levels. I have used McGeorge in the past. They are pretty good when it comes to getting OEM parts. Alas I am stuck with what I have for now.
Old Sep 10, 2022 | 05:45 PM
Jimkola's Avatar
YT Community Team
5 Year Member
You can always put Koyo/naichi bearings in your alt.
horunner1x
Jan 29, 2021 07:42 PM
1badrunner
Aug 10, 2010 05:52 PM
BeachSandChef
Mar 17, 2009 09:54 AM
duburban
Apr 27, 2007 06:38 AM
ayoung101
Oct 3, 2006 02:09 PM
