What is this bar called?
Old Jun 15, 2021 | 06:45 PM
joestox's Avatar
what is this bar called under the front of this '94 4runner? The rubber bushing things have all eroded away and I think this bar is making a lot of noise when I hit rougher roads. Are these rubber bushings easily replaceable?
Old Jun 15, 2021 | 07:26 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
Stabilizer bar. Helps to prevent 'yanking' when one wheel enters a deep hole or hits a bump, I believe is the theory. Yes, the rubber parts are readily available.
Old Jun 16, 2021 | 02:36 AM
arlindsay1992's Avatar
AKA sway bar. The bushings are easy to replace, two bolts per side. I'd remove one side at a time. The bushings are split so you just open them up, wrap them around, then bolt the metal bracket back up to hold it all in place.
Sometimes the bolts into the frame get frozen from rust but I think you'll be okay based on how the bottom of your truck looks.
Old Jun 16, 2021 | 10:09 AM
scope103's Avatar
https://www.rockauto.com/en/catalog/...r+bushing,7624
You'll probably want to replace the "end links" while you're in there. https://www.rockauto.com/en/catalog/.../+bushing,7580
Old Jun 16, 2021 | 11:08 AM
dropzone's Avatar
Fossilized
where is your truck leaking at? Front pinion seal leaking throwing all the oil everywhere? or the tranmission? looks like there is a gap on your trans
Old Jun 16, 2021 | 11:13 AM
joestox's Avatar
I'm actually trying to find the oil leak. what do you mean a gap on the trans?
Old Jun 16, 2021 | 01:11 PM
Dr Phat's Avatar
Jeez dude, that oil leak is a bigger concern than your sway bar bushings. Its a little blurry but it looks like there is a gap between your transmission pan and the housing.
Old Jun 16, 2021 | 01:18 PM
joestox's Avatar
LOL okay I'll take a look - I'm new to repair so trying my best. I'll shift my priorities. I doubt its a gap though....Seems like oil would be gushing out if that were the case.
Old Jun 16, 2021 | 01:25 PM
Dr Phat's Avatar
Looks like it all already did!
Old Jun 16, 2021 | 04:35 PM
wallytoo's Avatar
from the oil, i might look at the front main seal. not uncommon on the 3.0 to leak from the front. determine whether the fluid is motor oil, ATF, or gear oil (or coolant) and that will help narrow it down.
Old Jun 17, 2021 | 10:16 AM
joestox's Avatar
@wallytoo Where is the front main seal located? Like which part of the engine is it on?
Old Jun 17, 2021 | 11:25 AM
wallytoo's Avatar
at the front. it is where the crankshaft comes through at the bottom of the block, at the oil pan interface. the harmonic balancer attaches to it. the seal is behind the balancer. but first, determine what the fluid is.
Old Jun 18, 2021 | 09:03 AM
coopster's Avatar
What Wallytoo said. I think I'd drop my skid plate, get some degreaser spray and get as much stuff off as possible. Check for leaking power steering fluid too.
I think if you get it somewhat cleaner, you'll likely see where the biggest leak is, then formulate a plan.
Doug P
Oct 30, 2017 09:28 AM
BoostinChick
Jan 28, 2009 10:12 AM
az4x4runner
Nov 23, 2002 01:10 PM
