weird creek on 1993 pickup 4x4
i just bought a new 1993 5 speed 4x4, when i turn sharply into a driveway or something it makes a creeking sound from i believe the front end...what is this sound from becaue my dads truck does it and also some of my friends trucks do it, just something annoying id like to fix
thanks
brendonv
thanks
brendonv
It's PROBABLY, I'm not guaranteeing anything over the net, the steering stops. You have a metal vs plastic situation (I don't recall exactly, I think it's plastic heads on the wheel side, metal plate on the frame, but I may have that bass-ackwards) when you get onto the steering stops, and it makes a horrible noise, bit it's really a totally harmless nothing. You can throw some really thick heavy grease on them to quiet them temporarily, but most Toyota owners just get used to it as a quirk of the beast...
Edit: It's "creak" not "creek". A "creek" is a small stream. It really confused me when I first read the title
It is likely the steering stops as mentioned:
More info:
http://www.4x4wire.com/toyota/mainte...ront_end/lube/
More info:
If you read the caption that goes with that picture on the link, you'll see that the plastic cap is missing. There's the plastic part of the equation. It makes a worse sound than just the metal-to-metal does...
