Weber 32/36 high altitude questions
Old Aug 26, 2010 | 09:57 PM
yotaman90's Avatar
Is anybody running a Weber 32/36 at high altitude? If so, how does it perform? I'm preparing to order a 32/36 and I'm wondering if it would need to be rejetted since I live at and above 6900 feet. Any help is appreciated
Old Aug 27, 2010 | 11:14 AM
yotaman90's Avatar
Seriously, nobody?
Old Aug 27, 2010 | 11:57 AM
T_F_E's Avatar
Should be fine, you just have to adjust it according the the air. I lived at 10,000 feet for 16 years, just need to set it more lean than factory specs because there isn't as much air.
Old Aug 27, 2010 | 12:56 PM
yotaman90's Avatar
Cool, thanks!
Old Sep 6, 2010 | 07:45 PM
yotaman90's Avatar
Well, got my Weber a few days ago and installed it. It seems to run ok, but it has a funky idle. Sometimes it will idle perfectly, but most of the time it tends to surge. What could it be? I'm sure that I don't have any vacuum leaks, does it point to my altitude? Also, I'm not running a fuel pressure regulator seeing as the one I had was a Spectre piece of crap. Any ideas?
Old Sep 7, 2010 | 06:34 AM
yotaman90's Avatar
Bump!
Old Sep 7, 2010 | 08:16 AM
toyotasaurus's Avatar
First off, get a new regulator. Then double check your vacuum lines for leaks. After those two items are covered, adjust the idle mix screw and see where it's at to determine if you need a new idle jet.
Old Sep 7, 2010 | 12:59 PM
yotaman90's Avatar
Found the problem. When I removed the primary jet holder from the side of the carb to replace it with an anti-diesel solenoid, I forgot to take the jet from the holder and add it to the solenoid . Replaced the jet and all is good now!
kazuya2416
Apr 5, 2024 02:17 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
dumpster84
Apr 30, 2016 06:03 AM
calderp
Jul 27, 2015 09:58 AM
