Weasy's Cams for 3vze.
Old Jan 18, 2011 | 05:19 AM
  #121
blake.nemitz's Avatar
yea i want some too anyone know how much?
Old Jan 18, 2011 | 05:46 AM
  #122
xxxtreme22r's Avatar
Originally Posted by taikowaza
Hi Thrice. YES the cams are still available, directly through the manufacturer.
COLT CAMS INC
#54-3347 262ND STREET
ALDERGROVE, BC
V4W 3V9
604-856-3571
www.coltcams.com
quick question does this include these as well? https://www.yotatech.com/forums/f2/2...ng-soon-74580/ For the 5VZ guys?
Old Jan 18, 2011 | 06:27 AM
  #123
92 TOY's Avatar
colt cams shows YES.....but they also have the link to sea2sky which i guess is defunct.
so i guess the only way to find out is to contact COLT.
Old Jan 18, 2011 | 07:13 AM
  #124
Runner303's Avatar
I would also like to get in if we do decide to do a group thing.New to the forum but have read alot about this mod and wood love to do it to my Runner.
Old Jan 22, 2011 | 01:39 PM
  #125
92 TOY's Avatar
just sent an email to COLT CAMS requesting a price and I specified that they are the ones SEA2SKY used to sell for the 3VZE.
we'll see what happens. I will post any reply I get.
Old Jan 22, 2011 | 02:32 PM
  #126
dieselloco427's Avatar
Does anyone know the specs to these cams? I've got RV cams (402 lift 222 duration) in my 3VZ-E right now, in addition to oversized valves.
Old Jan 24, 2011 | 06:59 AM
  #127
Runner303's Avatar
I called Geoff on friday. Geoff told me that for my cams to be grouded down would cost 400$ and that included shims, and shippin. Forgot to ask about the group deal.
Old Jan 24, 2011 | 08:05 AM
  #128
MudHippy's Avatar
$400 isn't too bad. Considering the shims and shipping are free. I assume he only means shipping from, and not to his facility.
This would make it much more interesting for Geoff to run a batch of cams off the master profile, rather than making 1 at a time, which might irritate him (and he might not do it at all if there are too few). Economy of scale and all that.
His site says:
No job is too small for us!
http://www.coltcams.com/html/about-coltcams/index.cfm
Besides, he could make more money off us if he didn't offer a better deal on a group buy. Which is fine by me, because I still have no idea how long it's going to be before I get my funds situated.
Old Sep 9, 2011 | 01:03 PM
  #129
barthmonster's Avatar
So these aren't cams sold outright, they need your old cams to 're-grind' ??
Old Sep 9, 2011 | 02:58 PM
  #130
BMcEL's Avatar
Correct.
Old Sep 27, 2011 | 09:22 PM
  #131
sexonwheels's Avatar
Does anyone know where Johnny ever went, or did he just fall off the map?
I'd like to get my hands on a pair of these and I emailed Coltcams and got no response back?
Any info would be helpful.
Old Sep 27, 2011 | 09:36 PM
  #132
space-junk's Avatar
Sea2sky Tuning went under a while ago... Last I heard he was clearencing all his old stock for good... Dunno about colt cams, but if you can get the specs, contact delta camshaft and they can grind you a set for cheap...
Old Oct 2, 2011 | 04:25 PM
  #133
csout's Avatar
Geoff Bardal/Colt Cams ground my stock cams this summer, I'm just now getting around to re-installing them in the 3.0. $380.00 plus taxes. Turned them around in a week...
Old Oct 5, 2011 | 09:14 PM
  #134
Wicked!
You should put up a post here with some news and a sound bite, or a video would nice! Definitely Let me know how they turn out. These are my last hope before doing an engine swap. A couple more horse in the 3vze will keep me occupied for another couple years.
So are you rebuilding both heads or just replacing the cams? Cause a head rebuild would add another $800 to the table...no?
Old Oct 9, 2011 | 03:05 PM
  #135
csout's Avatar
Weasy's Cams
sexonwheels:
I'll post when I get this fired up. It'll be a while, this is a long term project, no hurry to get her fired back up. I've got headers, lift kit, axles and a brake conversion to go. Then paint.
dieselloco:
Specs for cam: .410 lift and looks like 216 duration. Spec sheet's not clear. C.701.s marked by Colt on the cams.
Old Oct 9, 2011 | 03:09 PM
  #136
csout's Avatar
Weasy's Cams
Also: price was $375.00 plus hst: $420.00 total. Just looked up the duration/lift on the receipt and saw I was wrong above.
Took some .0015" flat stock and cut 34mm shims for setting up the valve lash instead of trying to swap out the factory shims. Lash set up nicely with these farmered shims. Anyone else done this?
Old Oct 9, 2011 | 03:18 PM
  #137
csout's Avatar
I keep forgetting to reply to your questions at each post:
Engine is relatively new: 145000km, but the truck is old. Not planning on rebuilding the heads. It's got updated gaskets and looks near new. No plans for motor after cams/headers.
Old Oct 9, 2011 | 07:52 PM
  #138
MudHippy's Avatar
Say huh?
So you made yourself some .0015" shims out of flat stock, as in mild steel? Really? How? You some kind of machinist or something? Pretty slim tolerances on those parts. I suppose one could fab some up with the right tools...I guess.
HOWEVER...
Hate to say it...BUT...you're screwed. That's not going to work at all...for very long anyways. Better be some SLIGHTLY tougher grade steel than that for this particular application. How do I know the shims are so HARD? I ground some that were a little too thick down to adjust the clearance on my exhaust valves. Took me quite a bit of grinding just to make any noticeable change in thickness. Probably as hard a steel as I've EVER seen in my life/personal experiences.
Good luck with that!!!
BTW, how in the HELL did you get ALL the valves ANYWHERE CLOSE to the right clearance WITH ONE SIZE SHIM FOR ALL OF THEM?!
That CAN NOT be true...sorry...not buyin' it!!!
Old Oct 10, 2011 | 04:23 AM
  #139
I don't see how flat stock would work either. Tolerances and Machinist skills aside aren't those shims heat treated? It's probably why as MudHippy so delicately put it, "as hard a steel as I've EVER seen in my life".
Old Oct 10, 2011 | 07:51 AM
  #140
MudHippy's Avatar
Then I got to thinking ".0015" is awfully thin, can that even be right?"
Turns out...NO it can't be right. .015" can't even be right. The thinnest shim from the factory is .0866", and the thickest is .1399". So you'd need to stack 57.73 of your .0015" shims to equal the thickness of the thinnest shim from the factory. Not that you should EVER consider stacking these shims.
So all this basically means you're full of it...and you know what "it" is.
