Weasy's Cams for 3vze.
Old Oct 10, 2011 | 07:55 AM
  #141
csout's Avatar
Slim Jim Shims
Made these to go under the stock hardened shims. In all cases, after the cams were ground and re-installed, I had too loose a lash. Colt cams gives you a .024" shim to place under the toyota stocker. I figured I could use the thin stock to cut the same size as the items from Colt. They are nicely captive under the stock shim and should work. I'll give it a try. If it doesn't work out, I have a record of the shims sizes required and available at CHS.
Old Oct 10, 2011 | 08:06 AM
  #142
xxxtreme22r's Avatar
Still isn't gonna change the fact flat stock isn't heat cycled/tempered etc etc. I know I wouldn't want the junk that flat stock leaves in the head when it wears down. When they fail, goo luck with just getting the CHS stuff as your most likely gonna need a new head/cams at the very least, possibly even an entire motor. Not something I would try.
Old Oct 10, 2011 | 09:32 AM
  #143
csout's Avatar
Slim Jim Shims are OUT
Extreme - that's the input I need. I think you're right. The mild steel shim stock won't hold up for long. Heading out to the garage to remove them and figure out which ones to order from CHS. Thanks for the input.
Old Oct 11, 2011 | 12:28 AM
  #144
Green93's Avatar
Take my advice and don't try to mickey mouse some shims under the stock Toyota ones. A local machine shop re-did my heads and put extra shims under there. Within 5 minutes of start up one shim was spit out and mangled a lobe on my cam. The reason being the extra shim the machine shop used wasn't exactly the same size as the Toyota shim. It was able to rock in the bucket and the cam lobe spit it out. The colt cam shims have never caused me any problems. In most cases you have no choice but to use them since the cam lobe is ground down and Toyota doesn't make a thick enough shim.
Finally have mine back together after 5 months. Forgot how loud she is.
Jason
Old Oct 11, 2011 | 06:27 AM
  #145
csout's Avatar
Weasy's Cams
Thanks Jason;
I've already ordered (close to) correct sized replacements from CHS. I see you've got the same cams and a set of headers on your 3.0.
Two questions for you:
How do you like the LCE ceramic headers?
Where'd you order them from?
Actually, more questions:
Did you do the valve lash setup yourself?
How close together did you get the lash?
Where'd you get the replacement shims?
Cheers.
Old Oct 21, 2011 | 06:21 PM
  #146
WestCoastMoose's Avatar
I also have these cams installed. I ported around all plenum,intake and head openings using a dremel and got in about 1 3/4". I was told, but did not do the lip around the valve itself.
I will say I had the cams and shims adjusted at a reputable engine shop and within 3 months, I had under 75 psi in 3 cylinders. Now to get my warranty out of it, I had to take the heads off and take them back in. F that!
I did it myself.Luckily I also have numerous extra buckets and pucks. So the shims given with the cams,3 had to come out and re adjusted. [IMG][/IMG]
Seat of pants feel, easy 10 horse.Nice neck snap and OH so awesome highway power!
Old Oct 26, 2011 | 09:53 PM
  #147
sexonwheels's Avatar
Wow, looks shiny!
Do you have the engine back together and running normal?
Old Oct 26, 2011 | 10:40 PM
  #148
Green93's Avatar
Originally Posted by csout
Thanks Jason;
Cheers.
I really like the headers. I had a few fitment issues with the crossover pipe at first. I got one of the first sets so I guess they didn't realize the differences between auto and 5 speed setups. I bought the high flow cat and cat back exhaust from them too. I ordered right from LCE. It's loud. Everyone thinks it's a v8. Haha
I have done the valve lash before but had the lash setup by the guy who rebuilt my heads. He supplied the shims to get everything into spec. I have bought them from Toyota before but the pricing is terrible. About $30 for one shim.
If anyone needs a machine shop I know a good guy in abbotsford. Great work, fair prices and quick turn around. Let me know.
Old Jun 15, 2012 | 03:47 PM
  #149
Any updates on the build?...or on the cams?
Matt.
Old Oct 25, 2012 | 11:42 PM
  #150
Toreador's Avatar
So what happened? Pics?
LittleUgly
15
Jan 2, 2020 01:30 PM
buckz6319
Aug 5, 2017 03:50 AM
moparbay
Oct 6, 2015 09:24 AM
tylermx71
Sep 29, 2015 08:49 PM
whiteyota93
Sep 29, 2015 02:31 PM
