Weasy's Cams for 3vze.
Old May 30, 2008 | 08:32 PM
  #101
aviator's Avatar
Originally Posted by Bumpin' Yota
drivers side just north of the steering linkage. doing this will require a custom fabb'ed turbo manifold. This has been sometihng ive been kicking around doing for a long long long time.
So you're either going to hook forward off the existing manifold to the turbo and come back from there... or basically sort of cap off existing manifold and cut in to it up by #1 cyl. right? or are you going to re route the right side across the front of the engine? the latter might work if you went to an elec. fan.
What about the power steering box? won't it be in the way?
You might want to go to a remote oil filter while you re in there if you have'nt already it sounds like you're going to loose all the space to get at it.
Old May 31, 2008 | 08:12 PM
  #102
Bumpin' Yota's Avatar
I was planning on keeping the passenger side manifold, oem crossover and the existing flange from crossover, and the flange from the driver's side manifold. Then only using the actual flange(s) since they are separate from the driver's side oem manifolds. (Lots of grinding in my future.) From there it will be picking up the turbo, positioning it, and being really creative to get it to fit.
It's a little difficult to put into words what Ive decided to do but there is still some things I have to work out yet as well.
Old Jun 2, 2008 | 02:34 PM
  #103
aviator's Avatar
I think I get the jist of what you have in mind...
If you are removing things at all you might want to consider putting some header wrap on the cross-over. With the turbo your EGTs are going to get hotter increasing the chance of burning the #6 valves, the wrap might help a little.
Old Jan 15, 2011 | 01:48 PM
  #104
thrice's Avatar
Are these cams still made/for sale?
Old Jan 15, 2011 | 02:19 PM
  #105
taikowaza's Avatar
Hi Thrice. YES the cams are still available, directly through the manufacturer.
COLT CAMS INC
#54-3347 262ND STREET
ALDERGROVE, BC
V4W 3V9
604-856-3571
www.coltcams.com
Ask to speak with Geoff and mention that you're looking for the 3vze cams that sea2sky tuning sold in Vancouver.
I can't speak highly enough about these cams. The idle and torque are sweet. After several years, I still stick with my strong opinion that the 3vze (manual trans) is an amazing engine if you do:
-Cams
-Headers
-ISR Intake Pipe (keep stock air box and AFM: just replace pipe)
I don't even want to upgrade to a 3.4 anymore. I am very happy with my 3vze.
I often prefer driving the modified 3VZE to my 2UZFE Sequoia (no headers on that yet).
Good luck and I hope you get the cams!
PS. for those interested in upgrading to 1mm oversized engnbldr valves after you install the Colt (weasy) cams, here are some more specs (after a long talk with engnbldr and Geoff from Colt). Any errors are my own.
These are 1mm o/s valves: Head sizes are 43mm intake and 36mm exhaust, stem diameter is 8mm, OAL is 4.10" exhaust and 4.10" intake.
These accept the factory retainers, springs, and locks.
re: o/s valve clearances with colt cams: should be no problem with piston to valve clearance.
"1mm=40,000", and on the radius you are looking at 20,000 per extension on either side of the valve. This is such a small amount, that there should be no problem.
“Be cautious when taking off/putting on the intake cam (left bank). Be especially careful on removal and installation. because the thrust flange is very thin, and if the cam gets caught just a little bit, it will crack that flange. Be sure to make sure that it comes out evenly. That is where a lot of guys make a mistake, because the cradles will crack. The exhaust is not as crucial, it never breaks. the intake is so thin though, and is a tight tight fit. They are very expensive to replace"
Old Jan 15, 2011 | 02:49 PM
  #106
MudHippy's Avatar
As many times as as this subject has come up in the past few years, and you're just NOW going to tell us this?
You dirty dog!
Old Jan 15, 2011 | 02:57 PM
  #107
xxxtreme22r's Avatar
You dirty dog!
haha yeah, I remember seeing these while looking for cams for 92 Toy for his and I had seen these. I figured they were no longer made as I could not find much info not long after sea2sky had these listed for group buys. Forget where I had seen the original thread.
Old Jan 15, 2011 | 03:03 PM
  #108
MudHippy's Avatar
I don't stutter in real lfe, never have. But I sure do do in my posts. Ever wonder why every post I have is editted? There's your reason. What is that disorder called I wonder?
Old Jan 15, 2011 | 03:05 PM
  #109
Haha don't feel bad, almost every one of mine ends up edited, because I always forget to put something in. Too much of this I guess.
Old Jan 15, 2011 | 03:12 PM
  #110
taikowaza's Avatar
shoot didn't realize no one knew where to find the cams! I haven't been following the threads lately, but I got alerted to this thread 'cuz I was subscribed back in the day! If you want those cams give Geoff a call. He is a super nice guy. These cams are crazy nice. Just yesterday I was listening to the idle and I think it's getting even better with age. It's got a kind of off-beat rhythm to it that makes me really happy. Love my '92 Happy New Year to 86-95 Toy Trucks & 4Runners owners. Best forum on YT haha
Old Jan 15, 2011 | 03:31 PM
  #111
MudHippy's Avatar
Look, I'm just super-excited to know I don't have to go through DOA to finally get some. Somebody called toyotaperformance and they wanted some ungodly amount for theirs, which they're probably getting from DOA anyways. I believe it was in the $800-$900, just less than a grand, price range. AS IF! I've also been meaning to get ahold of a company near me in Portland, OR,(CHS Machine Co.)that sells a "Hi-Pro" 3VZE with high lift/duration cams in it. Which I strongly suspect are from DOA as well, same specs. And we all know why we don't want anything from DOA. So, I've been holding onto hope for the Colt cams option to become a reality. Now that it has, STOKED CITY BABY!!! SIGN ME UP!!!
Yeah, I've got a problem with that too. And I'm super-anal about spelling, and too dumb to download/use the spellchecker.
Old Jan 16, 2011 | 07:32 PM
  #112
aviator's Avatar
Great news thanks Taiko... I thought these cams were long gone... now I can put them back on my list...
Old Jan 16, 2011 | 07:42 PM
  #113
taikowaza's Avatar
Hey no problem aviator! Now I just hope that Geoff will still have them!
It's my thinking, that Geoff may have to make some new ones off the master profiles for the 3vze.
If you guys are interested, I would recommend making a list, and having everybody who wants them, buy them at the same time. This would make it much more interesting for Geoff to run a batch of cams off the master profile, rather than making 1 at a time, which might irritate him (and he might not do it at all if there are too few). Economy of scale and all that.
How many think that you might want a set? Is it just you aviator, and you mudhippy? I also have weasy's contact info and could find out if he has any left (not sure if he's been posting on YT lately). Either way, I hope you both get these cams because they rock. Let me know if I can help...and feel free to call Geoff on your own (I posted his # earlier). Good luck!
Old Jan 16, 2011 | 07:51 PM
  #114
MudHippy's Avatar
Yes, me for sure!
I will make this happen in the next month or two, no more than three...hopefully ASAP.
If it needs to be by a certain time/date I'll do my best to make it by then. I can promise you that.
Old Jan 17, 2011 | 08:26 AM
  #115
'934runner's Avatar
I would be interested too depending on price? What are we looking at here?
Old Jan 17, 2011 | 04:28 PM
  #116
space-junk's Avatar
thank god someone picked up weasy's slack... i was gonna get a set for my runner but he went under right before i had gotten all the money...
Old Jan 17, 2011 | 05:34 PM
  #117
phildelfino's Avatar
Ditto on pricing. Any number?
Old Jan 17, 2011 | 05:35 PM
  #118
92 TOY's Avatar
subscribed due to peer pressure
Old Jan 17, 2011 | 06:22 PM
  #119
I love being the motivating factor for people to git-r-done.
Old Jan 18, 2011 | 03:14 AM
  #120
92 TOY's Avatar
Oh I hate you guys spending my money and delaying this build......GRRRRRRRRRRRR
Not much experience with the 3vze....have driven it only about 10 miles in just under 2 years (see my son's build thread in my sig) and was not disappointed in the power but have read enough on this forum to realize I / we will be disappointed.
Going to start clicking around to read more about these cams. very MUCH interested in the prospect of opening the performance of this motor up a bit more. Doug Thorley headers are already here and waiting to be installed, motor is out and mostly disassembled and all are anxiously awaiting the day the motor goes back in.
EDIT:....pertinent question........PRICE???
