"Wandering" mixture screw
I have a 1993 Toyota Pickup. 22RE.
the idle had been getting rougher with the cold. It would high idle at 2100 rpm on a cold start and began surging when warm.
I adjusted the screw on the top of the throttle body and my idle was PERFECT. Cold idles never exceeded 1800 rpms for more than a few seconds.
However, coming to a stop sign or two lately the idles been chugging away at about 450 rpm. I'll stop and get out, pop the hood and adjust the screw with my handy-dandy glove box gerber multitool.
it'll be fine for a few minutes, hours or days... but it soon wanders again requiring adjustments.
What do you recommend I use? a washer? loc tite?
There is an O-Ring on that adjustment screw and yours is probably dry-rotted. I had the _exact_ same issues you describe after my recent rebuild. Surging idle, and constant re-adjustment of the idle screw. It'd back nearly all the way out sometimes which is what led me to understand it has an O-Ring.
I replaced the O-Ring and it is solid now. If you don't have - or can't find - an O-Ring, get it to where you like it (warm), and then smear some heavy grease around it and that will at least slow the movement. Not elegant, but will work.
i had the same problem with my idle screw. i could physically watch it wander when the engine was running. i didn't know about the o-ring at the time, so i just used some teflon tape from my toolbox, on the threads -- been working great for 4yrs like that.
Yeah, the rubber gasket on the mixture screw eventually turns to stone.
Chip it all out and go to your local NAPA/Autozone whatever and ask them to find you an injector o-ring that fits right. The local NAPA did it for free for me.
kawazx636
Oct 6, 2021 03:03 PM
zytra
Jan 24, 2019 03:16 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
