Universal fuel filter
Old Jan 18, 2022 | 01:49 AM
884RunnerSR5's Avatar
Hi all,
Are there any inherent drawbacks to using a universal 5/16" in-line fuel filter over the OEM Toyota one? My '88's fuel lines were rotted and while I replaced them with a mix of hard/soft line for now, the job isn't as good as I'd like. I was pretty rushed at the time, and could do a much better job running standard 5/16 line to a universal 5/16 filter which has male ends on it vs. the OEM Toyota filter which has female ends.
Thanks!
Old Jan 18, 2022 | 05:39 AM
arlindsay1992's Avatar
EFI or carbureted? The orifices in a fuel injector are much smaller and would clog more easily, that's why a fuel injection filter has a finer size. Also keep in mind the pressure is around 35 PSI, a regular filter may not be rated for that. If it's carbureted, a universal filter would be just fine.
Old Jan 18, 2022 | 11:35 AM
Mine is the 3VZE so EFI. The filter has filtration tolerance of 10 microns, which seems more than adequate. Doesn't give any info for pressure though so I'll have to call and ask. I believe my fuel pressure should be between 35-45 psi so nothing too crazy anyway. To be honest, my injectors are probably already clogged up anyway because the dip˟˟˟˟ who owned this thing before me was running it without a fuel pump strainer for god knows how long, so all that stuff is probably in there already haha.
Thanks for the insight though, I think I'm gonna try this out and see how she does. Parts cost to me is about $35 for the filter, clamps and the hose so if it doesn't work, I can go back to my system now.
Old Jan 19, 2022 | 06:51 AM
Jimkola's Avatar
YT Community Team
5 Year Member
If the universal filter is made of metal it might be worth trying. I wouldn't mess with a plastic one. Your fear isn't the filtration quality. You need to worry about the plastic housing splitting open and spraying gas at high psi all over a hot engine. That will not end well.
Old Jan 19, 2022 | 11:12 AM
akwheeler's Avatar
with an in-tank fuel pump all of the fuel lines are threaded connections unless I am remembering wrong.
your universal filter will be using hose clamps. not exactly a recommended practice for higher pressure found in EFI applications.
Old Jan 22, 2022 | 07:04 AM
cbh148's Avatar
My '94 is all threaded connections on the supply lines from the tank to under the firewall, under the firewall to fuel filter, and fuel filter to fuel rail.
Every Nissan 240sx ('89-'98, only ever made w/ EFI) uses the same arrangement for both the supply lines and the return lines as what these old Toyotas use for return lines only -- normal hose clamps holding rubber hose (high pressure fuel rated, of course) onto hard line with a bead roll to help keep it from slipping off. It's much easier to work with as there's no gasket washers, and no high-leverage break-prone threaded fittings on the fuel pump mount. Even the fuel filter.
If there was an easy way to cut off the threaded fitting on the fuel pump mount and add a bead roll / barb to it, and make the fuel rail have a similar provision for slip-on hose, I'd convert my truck to that simpler pressure line arrangement and use a 300zx fuel filter.
Old Jan 22, 2022 | 07:45 AM
Jimkola's Avatar
YT Community Team
5 Year Member
When confronting an assembly method on a Toyota, and pondering a possible way to do it easier/quicker/cheaper you have to ask yourself why Toyota opted for the slower/harder/more expensive method. I'm sure they had their reasons.
I'd assemble it the right way, that way I never have to worry about it down the road. Literally.
Old Jan 22, 2022 | 10:53 PM
cbh148's Avatar
Yeah, just like with plastic timing chain guides, delaminating head gasket materials, and ignition switch roasting starter relay wiring circuit configurations.
They got a lot of the stuff right, no doubt, but that doesn't mean there aren't some areas stand to have some improvement, especially in cases where discontinued parts become a factor. And in the case of the fuel line threaded fittings that like to break off the pump mount lines due to age & leverage (making dropping the tank somewhat risky for some people), a little brazing could go a long way.
95yoda
Apr 17, 2009 04:15 PM
jungle_runner
Mar 30, 2009 07:05 PM
TNRabbit
Jul 31, 2006 04:33 PM
BornChaos
Feb 20, 2006 09:11 AM
vickers88
May 8, 2005 05:32 PM
